Originally posted by PentaxPoke I think that people that compare camcorders with DSLR video don't really understand how limiting camcorder technology is, and what a major breakthrough DSLR video really is. The significance boils down to sensor size.
PentaxPoke, you are right. Even after the following extra detail ...
Current dSLR video only uses a (small) fraction of all sensor cells found on their sensors. Called subsampling. This doesn't limit their DoF capabilities but it does limit overall image quality and low light capabilities.
E.g., the K-7 uses 1/6 of all sensor cells, the 5DmkII slightly more, most likely 1/3, and all entry level dSLRs I am aware of use less than the K-7, incl. the K-x.
Therefore, on the one hand, dSLR sensors should be scaled to 40% (linear dimensions) for a fair size comparison with camcorders (24% when comparing with a 3 chip camcorder). And even when doing so, dSLRs win hands down.
On the other hand though, this shows how dSLR video currently is at its infancy. When developped to its full potential (supersampling all sensor cells), video with system cameras (some of them being dedicated video cams of course) will blow everything else out of the field.
I believe this is at the root of the current dSLR video hype. It is a hype in the video community.
A hype which has nothing to do with the still photographer community, of course, and can be ignored by them.
