Originally posted by falconeye I noticed the diagonal discrepancy.
I finally managed to sort the discrepancies out of the Kodak document.
Here are the data as they appear to be correct. The document is using wrong labels.
1. Pixel pitch: 6.000 µm (turns out to be an exact figure !)
2. Image diagonal of active region: 54.78 mm (as given correctly)
3. Aspect ratio of active region: 7304:5478 or 4:3 (exact)
4. Size of active region:
43.82 x 32.87 mm (or 44x33 when rounded, matching both H4D-40 and DALSA DM40; 1.667x the surface of FF).
5. Size of area filled with pixels: 44.41 x 33.40 mm
6. Size of mechanical cover cutout: 45.76 x 35.34 mm (cf. page 33 of the long specification, incorrectly labelled "size of active region")
The data given in the Hasselblad document (44.2 mm rather than 43.8 mm) is compatible with assuming a different counting of dark and buffer pixels.
To summarize: both, Kodak KAF-40000 and DALSA DM40 match the Pentax specification (1.7x FF surface, 44x33mm, 40MP). Personally, I believe that Kodak is the more likely partner then.
