Originally posted by Jonson PL Thanks for the link.
The AF tracking of the K7 should be acceptable, but the frame rate drops quite a bit.
One user left Pentax to pursue his interest in motorsport, but he commented that his first outings, with the D300 as I recall, didn't give him more keepers. But of cause there is a learning curve
Not sure what would cause the frame rate to drop on the K-7. It should continue to fire even if the subject is out of focus.
AF tracking on the D300/D700 takes some time to master. There are many (too many???) settings available. While in continuous AF mode, you can track subjects based on 1, 9, 21, or 51 AF points. If using 51 points, you can also add-in "3D" tracking to the mix. On top of all that, you can have the shutter release only if the camera achieves focus, regardless of focus, or somewhere in between. You can also set the duration of how long something remains in focus before it switches to lock on to something passing in between you and what was previously in focus. My point is that it takes some practice to get the most out of any camera, given a specific scenario.
Somewhat off-topic, but is there any chance a K-x may actually track better than a K-7? I noticed the K-x has 2 AF modes - AF1 turns on 5 AF points and AF2 activates 11 (I think) AF points. Is it possible that the K-x could track smaller subjects faster using the smaller grouping of 5 points, instead of 11? Has anyone commented on the K-x's ability to track?
