OK I am modifying an extra battery grip I happened to have to fit my K-X, so I read through this entire thread.
It gave me a lot of ideas!
Here is my unfinished grip :
https://www.pentaxforums.com/forums/pentax-beginners-corner-q/129995-hey-i-or...ml#post1479953
Here are my replies to some of the posts :
Originally posted by phzy2003 maybe not, because there is nothing can connect with the grip on the body
The tripod mount
Originally posted by Pentaxian210 I have to say, this is keeping me from buying this camera. All the great reviews and it just lacks some of the things that I fell in love w/ on my K200D. The grip on the K200D makes it a beast! Also, the size of the KX seems way 2 small for me. I guess I'll keep saving up until I can get my hands on a K7.
The K-X has a lot more going for it than the 200D, see the snapsort comparison :
Pentax K-x vs K200D Originally posted by knoxploration ...the battery compartment door can't be removed, which limits the options for using a dummy battery to pass power through from a grip.
You could use AA dummies to make contact with the (presumed) Lithium grip batteries, they sell AA dummiies on eBay :
dummy battery AA | eBay
But you'd have to drill a couple small holes in the K-X battery door to allow the wires to pass through ... But upon closer inspection, my KX has a hole on the side of the battery compartment for running wires through, it's covered by a removable peice of rubber. So you can run wires from dummy batteries without drilling any holes in the K-X battery door
I guess Pentax did count on a 3rd party grip coming out ???
Originally posted by timstone I think they could make it work if they wanted to. The battery door does open up to a 90 degree angle to the bottom of the camera, which means they could effectively make a grip for the camera and instead of removing the battery door they could have some way to secure it to the grip...possibly the same way it stays closed on the body of the camera.
That's a good idea
Originally posted by rawr Pentax isn't unique in not giving the K-x a battery grip option. It's worth noting that in Nikon-land, entry level DSLR's like the D3000 and D5000 also do not have battery grip options.
3rd party grips are available for Nikon D40 D40x D60 D3000 D5000, now down to like $26 USD
They use 2 rechargeable lithium batteries and provide a vertical shutter release using a built in remote shutter release.
I used one by Targus back when I was shooting a D40, and it really transformed the camera, it was great. I later upgraded to a K-X and sold the D40.
The K-X trumps the D40 but I miss that grip LOL
Originally posted by knoxploration Ah, didn't notice the slot. I'd say it's pretty unlikely it'll fit - it'd rely on the distance between the tripod mount and battery locations being identical *and* the battery door being the same size or smaller, and the same distance from the tripod mount, *and* the battery door and batteries having identical orientation with respect to each other.
That's a lot of ands - and they're not likely to pan out for you given that the K100D / K110D are bigger than the K-x in every dimension, and have a different battery door design.
You could modify the grip, dremmel to cut and JB Weld to "add plastic"
Anyway, after reading this entire thread and seeing the K100D battery grip, the MB-18 modified grip, the AA dummy batteries, and my own progress - I think we can all make battery grips LOL
Cheers,
Craig
