Originally posted by FlashCube How did you do the -100u correction?
I created MODSET.445 file with
[DEBUG_MODE EN] enter
[OPEN_DEBUG_MENU] enter
inside.
Hint - last line must be present, so after
[OPEN_DEBUG_MENU] you must press Enter.
Copy file to root on SD card and insert to camera.
Power on with card door open, press MENU, (you will get list of menu with DEBUG MODE ON on top) press OK.
Power OFF, close card door, power on, and you got acces to AF adjust.
I corrected little BF with -100u value.
After all you corrections are done.
DEBUG MODE ON on top) with arrows change DEBUG MODE ON to OFF, and press OK.
Power OFF, close card door, power on, and thats all. Camera is in normal state.
I made this operation after software upgrade, to check if my correction was not reset, so with my K200D it still works fine.
