Hello all!
Newly registered member here just wanted to share some images, thoughts and had a few questions.
I'll start off with my thoughts on the camera. (Nothing too in depth just quick thoughts)
UI: My first GR Digital (shot with the gr1s before which was also very good) and the UI and customization is perfect, even after coming from the older x100. Took me a day of shooting to set every button to what i want, never read the manual the main menu is seriously straight forward.
Ergo: Very very comfortable in the hand. I went into Samys prior to picking up a GR and played around with the Nikon A. Although the Nikon A was very solid and robust feeling, the handling was not comparable to the Ricoh to be honest. The Ricoh is so light, reminds of the GR1, easy to carry around. I do not like the hand strap though, I need to wrap my middle finger around the strap while on my wrist as to not having it slip out of my hand.
AF: In daylight its fast, in semi low light its decent, and in very low light it hunts. But I am not a quick draw shooter and because i shoot alot of film I am used to addressing a scene and taking my time before releasing the shutter.
IQ: This impressed me the most. The tonal qualities and dynamic range remind me of film. I have only worked with OOC jpegs so far but they are very nice to work with in LR in terms of tone adjustments. **I'm comparing this experience to that of the x100 which was nice but I was never completely amazed by its IQ and malleability in post.
Charging: Did not come with a dedicated wall charger but instead a usb charger. It charges through the camera which is good and bad. I would like to get another battery charge it while still being able to use the camera.
Which leads to my question: Will charging the camera through a USB iPhone car charger ruin the battery?
Thanks for reading.
Images (with tone adjustments only):
Last photo was taken at night, dim parking lot lights and was handheld.
***ALL IMAGES ARE OOC JPEGS AND EDITED IN LR3
I update my tumblr (archi-tap.tumblr.com) and flickr often, you all can check back for more images from the Ricoh.
Thanks for reading my long post!
Marc
