09-05-2013, 12:57 AM   #1
Ricoh GR circular rings artifacts in the pictures
Hi guys! I've found this problem on my GR, when shooting in low light conditions and try to pull up the exposure.
Here's some images, the first one is as taken, second one is the same image pulled up 4 stop in ACR.
Someone here having the same problem?
GR  Photo
GR  Photo
Last edited by seyfer; 09-05-2013 at 01:08 AM. Reason: Make understanding better the title
09-05-2013, 01:49 AM   #2
I think that lens should produce a high amount of vignetting that is corrected by in-camera software - it is often the case for micro 4/3rd or compact camera, they simplify the lens design, and correct the image by pushing the exposure to counter vignetting.
As you have pulled up the image 4 stops, the additional 1 or 2 stops added by in-camera vignetting correction is too much for the sensor to recover. Particularly if you have a jpeg image which is coded on 8 bits.
Cheers
09-05-2013, 02:24 AM   #3
QuoteOriginally posted by goubejp Quote
Cheers
So you think it's just a software problem? In this case I'm ok, just hope it's not an hardware thing...
Anyway I founded some other discussions about it,
Ricoh Forum • View topic - Red Circles in underexposed pictures
09-05-2013, 02:53 AM   #4
Us this from a RAW or JPEG?
09-05-2013, 03:42 AM   #5
QuoteOriginally posted by Giklab Quote
RAW file.
09-05-2013, 07:25 AM   #6
Aristophanes's Avatar
Do you have any sort of highlight or shadow correction on?
That is definitely the lens profile, supposed to be controlled in-camera. Obviously at 4 stops it exceeds the parameters as noted in a post above. Any sort of correction may exacerbate that.
09-05-2013, 07:54 AM   #7
In a RAW? I somehow doubt Ricoh would go that far... especially in a GR. My explanation is, that the rings ARE the vignetting, but since they are darker than the rest of the image, they show up when doing extreme shadow pushing.
digital camera, gr, ricoh gr
Getting to know the Ricoh GR: day one Magica Ricoh GR 6 11-15-2013 02:44 PM
Ricoh GR in stock at UK dealer on eBay. theperception2008 Ricoh GR 6 06-01-2013 01:29 AM
The Ricoh GR is here (first impressions)! Adam Ricoh GR 25 05-31-2013 09:58 AM
The new Ricoh GR anthony mazzeri Ricoh GR 20 04-29-2013 04:12 PM
All times are GMT -7. The time now is 10:03 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
