09-28-2013, 09:42 AM   #1
Macro Ring Flash for Ricoh GR?
Hello Everyone...
I just got my new Ricoh GR at the beginning of this month and I'm beginning to love shooting macro using the macro mode
I have a plan to use the macro ring flash on my GR, is there anyone using it on the GR?
Since it is pentax forum, is the AF160FC Auto Macro Ring Flash compatible for the GR plus GH-3 adapter?
I'm waiting for your opinions and experiences
Thanks in advance
09-28-2013, 04:10 PM   #2
jup
Haven't tried that, since I don't have GR adapter, but I tried regular Pentax mount flash and P-TTL does not work (which is expected). I am pretty sure the situation with AF160FC will be the same. It will mount easily (since adapter thread is 49mm and AF160FC comes with 49mm adapter), and it will fire but without P-TTL. With AF160FC that means you're limited to 3 manual settings: FULL, 1/4, 1/16. That said, the manual that comes with a flash has nice table "subject distance/flash power/aperture/ISO", so you could get around that using excellent distance scale of GR and, in fact, P-TTL metering in Macro is approximate at the best.
But you may run into other problem - AF160FC at 1/16 power is too powerful for GR macro distances. Consulting the above mentioned table: ISO 100, 1/16 power, f/16 -> subject distance 0.25m. Luckily, ND filter will probably cut this to half, or give you equivalent of f/32, but that still goes to 0.13. You may get less light by using just half of the flash, but my assumption would be that lighting subjects at the maximum GR magnification (0.10m and that's from sensor) would be tricky at best. Which is a pity, because at P-TTL flash can go all the way to 1/64.
Bottom line, I wouldn't buy the flash just for GR, and you might be better of with some LED based flash for such a short distances. But if you are thinking about using it on some Pentax camera anyway, it's a wonderful toy...
PS: The other issue is that your subjects may spontaneously burst into flames being so close to the flash.
10-07-2013, 12:51 AM   #3
QuoteOriginally posted by jup Quote
thanks a lot for your answer
it has given me a broader understanding
digital camera, flash, gr, macro, macro ring flash, ricoh, ricoh gr
Ricoh GR - missing lens ring frankoz Ricoh GR 3 10-23-2013 09:51 PM
For Sale - Sold: Pentax DA 21mm F3.2 LTD for RICOH GR V hongzhibin1987 Sold Items 3 09-02-2013 10:34 PM
Ricoh GR- Red Ring Giveaway! Adam Ricoh GR 18 08-01-2013 12:59 PM
Ring flash / ring light for macro tcom Flashes, Lighting, and Studio 5 07-28-2007 10:26 AM
All times are GMT -7. The time now is 03:33 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
