10-30-2013, 12:22 AM   #1
GR autofocus noise?
Looking for some to help to determine what I'm hearing from the GR when autofocusing is normal. Occasionally when autofocusing, mostly in macro mode or regular AF mode closer to an object, the lens emits what is somewhat of a 'grinding' sound while it autofocuses. This doesn't happen all the time, I noticed it's usually when it's hunting for focus and will emit this short whirling grinding-like sound. This can repeat if the AF is hunting for focus.
I used to have a GR D IV and did not encounter that, so I'm wondering if this is normal? I assume the AF motor emits some sound but I'm not sure if what I'm hearing is it. I bought this camera used so trying to figure out if something is wrong with it.
10-30-2013, 12:28 AM   #2
It you're able to capture the sound in a video, that would be perfect as then we'd able to give you a better answer.
For reference, here's what the AF should sound like:
Ricoh GR vs. Nikon Coolpix A Review - Autofocus - PentaxForums.com
11-12-2013, 09:16 AM   #3
QuoteOriginally posted by HibikiRush Quote
Just registered to comment on this particular question (though as a GR owner who is contemplating the K5iis to replace M4/3, I'm glad to find this resource).
I heard a noise for the first time with the camera on AF, and "grinding" is a fairly accurate way to describe it. A quick google lead to this thread but not much else. Normally if you listen real close there are two sounds, the motor and the gentle click of the aperture blades. This was a third noise, in my case when half pressing the shutter button to AF. It happened a bunch of times, at different fstops, and was quite noticable. After I turned the camera off and back on the noise had gone away.
I'll report back if I hear it again.
af, digital camera, focus, gr, mode, ricoh gr, sound
Noise...noise..do I need software? ejbpesca Photographic Technique 15 04-07-2011 03:39 PM
I was just wondering -- Autofocus noise redeleon Pentax DSLR Discussion 2 04-28-2010 06:50 AM
Help! Autofocus switch stuck on AF.S and will not autofocus! pauldiebel Pentax DSLR Discussion 3 09-19-2009 08:59 PM
For Sale - Sold: FS: Autofocus film cameras and autofocus lenses Not Registered Sold Items 15 03-17-2008 07:08 AM
All times are GMT -7. The time now is 01:08 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
