12-31-2013, 06:51 PM   #1
GR -- how to use Bulb and Time?
Shopping for a GR. Noticed it had Bulb and Time settings, which I dearly loved back in film days.
Back then, we could screw a cable into the shutter-release button. Can't do that here, looks like.
On my K-01, I can use the Pentax F remote to take a picture. Can't do that here? I can't see an IR window on the front or back of the GR.
So -- how do you use Bulb and Time? Is holding the shutter button down manually the only way? What am I missing here?
12-31-2013, 09:50 PM   #2
Canada_Rockies's Avatar
Bulb is hold down, Time is press to open, press a second time to close. There is probably a remote for the GR. See if you can find an on line manual before you shell out the money.
12-31-2013, 11:30 PM   #3
@Canada_Rockies -- yep, it's RTFM time here in San Diego! Downloaded the manual, found a reference under Bulb and Time for the CA-2 optional cable switch. Checked on Amazon -- it's there. Ricoh CA-2.
A note for anyone else interested in this -- the older, less expensive CA-1 cable switch will NOT work on the GR. The USB plug is different. But the CA-1 will work on the old version of the GR. 'What's in a name?' Confusion!
bulb, button, digital camera, gr, ricoh gr, time
curious how to best use qk adapter and m42 lens pearsaab Pentax Q 6 10-29-2013 05:53 AM
How to disable 360FGZ and Metz 48 AF beam and use K-7 body AF beam raider Pentax Camera and Field Accessories 5 03-17-2012 03:43 PM
Going to extremes, how to best use extreme focal lengths both near and far icywarm Photographic Technique 9 04-23-2010 07:54 PM
Lens hoods - Why use them? How to know what type to use? noahpurdy Troubleshooting and Beginner Help 12 12-05-2009 11:30 AM
When and how to use SR and how effective? Takman Pentax DSLR Discussion 11 11-02-2007 07:37 AM
All times are GMT -7. The time now is 01:59 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
