Update, a few hours later --
It might be me, not charging the battery properly. Have the Wasabi charger -- went back and re-charged a battery, making sure this time that the red light came on when I plugged it into the wall -- and, after charging (green light comes on), this battery shows a full charge on the GR battery indicator -- that stays at the full level after taking a bunch of pictures, as it should.
Re-charging second battery now -- will see if it shows full also. Stay tuned.
EDIT -- second battery charged properly, shows 100% in the GR indicator. Looks like this is my error, sorry for the false alarm -- hopefully it won't occur again.
EDIT EDIT, a day later -- definitely me. The batteries are just fine, the battery indicator is just fine. Took a lot of pictures today without any problems.
Moderator -- if you want to delete this thread, please go ahead. Non-issue.
