06-12-2015, 01:23 PM   #1
white balance
It seems no matter what I do, most of my photos are shifted toward the green and away from red. I've been experimenting with manual WB but shouldn't have to, especially on a simple bright, sunny day. Any one else having this issue and/or have suggestions?
06-12-2015, 01:38 PM   #2
What setting do you typically use? Auto WB?
06-12-2015, 01:55 PM   #3
enoeske's Avatar
QuoteOriginally posted by kines Quote
Maybe your monitor isn't calibrated and it skews toward green?
06-12-2015, 02:17 PM   #4
Maybe you just want to tweak your jpeg settings a bit?
06-12-2015, 02:58 PM   #5
K(s)evin's Avatar
Try adjusting the Hue instead of the WB.
06-12-2015, 05:20 PM   #6
Thanks everyone.
What does "tweak jpeg settings" mean? On my GR3 I could manually move the RGB grid, but don't see that capability on this one.
And what does "adjust hue" mean? Is that a camera setting, or are you talking about on computer software? If the latter, yeah, I can do that, but I'm really just wanting a reasonable result out of the camera so that I don't have to.
I've tried AWB a lot. Outdoors in sun I've tried "sunny" and "cloudy". All of them result in greenish photos.
I have definitely considered the monitor as a possibility, and ruled it out. Same result on several different monitors. Also, I can compare it to my other cameras, and internet photos, all on the same monitor, and yes, the Ricoh photos are green.
May have to just resort to RAW. Or carrying around a white card with me to manually set it all the time.
KN
06-15-2015, 07:16 PM   #7
OK here's a link that you can use to toggle back and forth (give it time to fully load) between the typical result from my camera (using either auto WB, sunny, or cloudy), and a corrected version using "remove color cast" in Photoshop. So is it just me? Again, the photo out of the camera looks green to me, and the corrected photo (using the lid of the coffee cup as white) looks spot-on to me.
http://216.254.17.117:2014/awb/awb.html
Thanks
KN
06-26-2015, 01:57 PM   #8
partial fix
In case it ever helps anyone else with the same problem who finds this thread in the future, I found at least a partial fix for this problem, and it is not included in the instruction manual, although it almost is. On p92, under "correcting the white balance", instructions are given for changing a photo once taken, but what it doesn't tell you is that the same feature is available during shooting by pressing the F2 button while selecting any of the WB modes. I simply moved mine over to the A:2 M:2, and the photos are much improved.
digital camera, ricoh gr
white Balance macman24351 Troubleshooting and Beginner Help 5 12-19-2014 04:45 PM
A question about white balance jford Photographic Technique 7 04-25-2014 04:47 AM
Custom White balance Eder Troubleshooting and Beginner Help 7 04-01-2014 10:23 AM
K3 white balance kieffer Pentax K-3 9 03-12-2014 01:03 PM
K5 white balance problems ryan.wadsworth Pentax K-5 6 01-21-2014 11:53 PM
All times are GMT -7. The time now is 09:58 AM. | See also: NikonForums.com, part of our network of photo forums!
