11-02-2015, 06:28 AM   #1
LennyBloke's Avatar
Anyone tried a GW1 on a GR
As the title says really...
...has anyone tried using the older GW1 21mm conversion lens on a Ricoh GR?
I'm assuming some combination of Adaptor plus maybe a step-up/down ring would be required
11-28-2015, 01:33 PM   #2
chickentender's Avatar
QuoteOriginally posted by LennyBloke Quote
Never tried that - the prices for all the GWs are roughly the same and yes, you'd have to do a conversion - 49mm-->37mm step-down... but other problems may appear in rendering.
I do have a GT-1 which I use occasionally with a step-down ring as above. The corners are EXTREMELY soft, almost a holga-like filter rendering, depending on the aperture used. For atmospheric shots or whispy portraits it can actually be quite fun, but definitely not an everyday sort of combination.
01-01-2016, 05:50 AM - 1 Like   #3
I stumbled onto this website Ricoh GR + GH-3 + Adapter Ring + GW-1 ? Canned Elf
I used the same setup as this person; a Ricoh GR (V) with a GH-3, step down ring and a GW1 works quite well actualy. I don't use it a lot, mostly for landscapes.
01-28-2016, 12:55 PM   #4
webstertomkins
Guest
I'm not sure, if it helps you. I have a GR II and I also have a wide-angle DW6 (fits to my old Ricoh GX100). The GR II has 49mm and the DW6 has 43mm. I bought me a step-down ring to use the DW6 on the GR II. I didn't made any pictures with this combination up to now, but from a look through the display it works. I do not see any vignetting.
05-09-2016, 11:09 PM   #5
Please i need help,
I was wondering if accessories like gw-1 and GH-1 are compatible with GR 2 2015 can they be used at all on this camera. Found them as a good deal but do not know if they will work / operate at all with Ricoh GR2 ?
Thanks, please anyone with experience on this.
digital camera, gr, ricoh gr
Anyone tried using a Schneider .6X WA HD ADAPTER 72MM THREAD to capture FF effect? choong_dc Pentax SLR Lens Discussion 3 09-26-2015 07:48 PM
Has anyone tried fitting a speed booster between a Q and a k-mount lens? Mothballs Pentax Q 5 06-23-2015 07:13 AM
Has anyone tried a Pentax 18-135 WR on k10d? mersault Pentax SLR Lens Discussion 5 07-08-2012 06:36 AM
Has anyone tried the new Sigma 8-16mm? Seems a hell of a lens... Unsinkable II Pentax SLR Lens Discussion 15 05-25-2010 08:34 PM
Has anyone tried a K100D battery grip ? spystyle Troubleshooting and Beginner Help 7 08-24-2009 10:23 AM
All times are GMT -7. The time now is 05:45 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
