Originally posted by Barresian Can anybody recommend some article, video or similar about shooting at 28mm? How to do it and what it's good or bad for? (besides the obvious imposibility for classic portraits and shooting wild bears). Found some interesting but rather superficial material.
The GR lens is actually an 18mm, just a friendly reminder
Same as your 18-55mm kit lens at 18mm.
The field of view corresponds to that of a 28mm on full-frame.
Originally posted by Barresian The Sony RX100 has been mentioned. I know the IQ difference is going to be important between both cameras, but how good is the RX? For example, compared to my K10 with the 35 DA, is there going to be a lot of difference? If I can get near to that with the Sony I think I'd be happy.
At low ISOs the two will probably be neck-and-neck, and you'll probably get better JPEGs thanks to the more modern engine in the Sony. At higher ISOs the Pentax should pull ahead a bit. Notice how generational differences are counteracting the sensor size advantage.
According to DxO sensor test scores, the RX100 has the same overall score, same color depth, slightly better dynamic range, but slightly worse high-iso performance.
Sony Cyber-shot DSC-RX100 vs Pentax K10D
If you were to upgrade to a K-5, on the other hand, you'd blow the RX100 out of the water because it has a more modern sensor.
Here's a sample from the RX100, hand-held at base ISO:
ISO 1000:
PentaxForums.com Webmaster (
Site Usage Guide |
Site Help |
My Photography)
PentaxForums.com server and development costs are user-supported. You can help cover these costs by
donating or purchasing one of our
Pentax eBooks. Or, buy your photo gear from our affiliates,
Adorama,
B&H Photo,
KEH, or
Topaz Labs, and get
FREE Marketplace access - click here to see how! Trusted Pentax retailers:
