Originally posted by r8n
If you are looking for the +/- setting in the menu, it is in the shooting menu, fourth section down (headed by white balance) just after ISO setting.
Thank you r8n, but not on my menu it doesn't. Mine goes" WB, ISO, ND filter, SlowShutter Speed NR. Believe me not a sign of "exposure compensation" on the menus, unless I'm doing something wrong, e.g. the camera has to be in a certain "mode," etc
---------- Post added 06-29-16 at 09:33 PM ----------
Originally posted by D1N0
you can use the + - button on the back
Thank you D1N0. Yes, the manual clearly states this and it seems such a great solution, but doesn't work on my newly purchased GRII. I think I have a gremlin in mine because it will not allow me to update to the latest firmware either - but I'll put this in a separate post. Peter
---------- Post added 06-29-16 at 09:35 PM ----------
Originally posted by DogLover
My biggest issue with my GRII is that +/- button on the back. I am constantly hitting it inadvertently.
thank you DogLover. I assure you this problem doesn't exit for me because hitting the +/- button does nothing!
