04-23-2018, 01:47 PM - 3 Likes   #1
The magical self-repairing GR
My GR photo playback button broke approximately 1 year ago. Around 1 month ago it started working again. I waited a few weeks before posting this to make sure it wasn't just momentary good luck. My luck has held.
The problem was likely triggered by a minor water immersion. My aftermarket pouch fell into water, stayed afloat, and was retrieved within 1 second. I immediately removed the camera from the pouch. There were only a few small droplets of water on the camera; the pouch did not soak through but the zippers are not waterproof. I wiped the camera dry and everything seemed fine for a few days.
The playback button became increasingly unreliable then stopped working around a week later. I assumed some water made it into that switch and caused corrosion or left dirt behind. Contact-cleaning spray, extra drying time, and full reset made no improvement. Everything else was still working fine; if I had to lose a switch that's probably the least-bad one.
I swapped batteries last month, accidentally hit the playback button, and got an image! It either took an exceptionally long time for the switch to dry, or the internal corrosion/dirt finally scraped off.
Today is a warm, sunny spring day. It's nice to have my favorite street photography camera working 100%.
04-24-2018, 03:17 PM   #2
All you need now is for it to hold out until the magical GRIII.
button, camera, digital camera, gr, luck, month, playback, pouch, ricoh gr, switch, time, water
Purchased Metz 26 AF-2 for Pentax GR on advice of B&H; GR won't recognize it Mainerinfl Ask B&H Photo! 2 03-05-2018 05:33 PM
GR store, no GR III i83N Pentax News and Rumors 14 07-13-2017 07:16 PM
GR / GR ii - rough idea of shutter count/longevity? Conqueror Ricoh GR 3 04-20-2017 11:36 AM
K-x AF after self-timer for Self-portrait sir.b Pentax DSLR Discussion 7 12-30-2009 07:53 PM
All times are GMT -7. The time now is 08:08 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
