09-28-2018, 07:45 AM   #1
Anyone recommend a case for GR II?
I've had a look at the Ricoh GC-5 leather case and I'm not a big fan. Bit too fiddly and flashy, and the reviews are not great, with the two halves coming apart too easy...
So I'm looking for a recommendation for a simple pouch type case that will keep the dust and dirt out, provide a little padding, and fit quite snugly without adding too much bulk.
Thanks in advance.
09-28-2018, 08:32 AM - 1 Like   #2
jlstrawman's Avatar
QuoteOriginally posted by victormeldrew Quote
Don 't know if you can get this from the UK, but the one I have is very nice.
https://optechusa.com/hipster-pouch.html
09-28-2018, 09:12 AM - 1 Like   #3
I use a Pearstone OCP250B CB1212 case. I selected it by visiting B&H and testing my GR1 (same size as GR2) in a lot of cases.
It's a fabric, zippered case with a little bit of padding. GR1 and two spare batteries barely fit.
I use the belt loop. I think it came with a neck strap, too, but I discarded that long ago.
09-28-2018, 09:22 AM   #4
A search for 'neoprene lens pouch' returned options. I bought one years ago for my GR and it works well (no dust so far).
09-28-2018, 01:42 PM   #5
QuoteOriginally posted by jlstrawman Quote
Hipster Pouch | OP/TECH USA
Seems to be discontinued...but optech have a few options I will check out, thanks.
---------- Post added 09-28-18 at 01:44 PM ----------
QuoteOriginally posted by DeadJohn Quote
I can't find this one either. But your post made me think that maybe the best bet is to visit a couple of camera stores with the GR and see what fits best. Thanks.
09-28-2018, 03:38 PM   #6
ma-ledezma's Avatar
I don't own a GR, but you can check B&H Photo they listed the following item for your camera. Ruggard HFV-250 Protective Camera Case.
10-02-2018, 05:38 PM   #7
Eyewanders's Avatar
Thanks in advance.
Most of the time I use a sunglass, microfiber pouch - the simple fabric type with a drawstring.
But the case I've used for all my GRs was Lowepro tiny thing I picked up in an electronics store back in '09 for my GRDIII. I used it for the GR as well.
But last year (earlier this year perhaps? can't recall) I bought a GRDIV because I'd been missing the GRDIII since parting with it so sought out another case for the GR since it was rather snug in the Lowepro.
TL|DR .... this is the case.
AmazonBasics Case for Point-and-Shoot Camera Large: Amazon.co.uk: Camera & Photo
The only thing I don't like are the zipper pulls which are metal and so they "click" when you the hit the zips. I've been meaning to cut them off and replace wit cheap replacement backpack zipper pulls but haven't gotten around to it. I have the LARGE version but I think the MEDIUM might work as well for the GR. With the Large version I have I can fit the GR inside with the adapter attach with a lenscap, or with my small hood ... but just barely. Without that attached there's plenty of room. Two spare batteries fit in the outside zip in either scenario. Works well. And it's cheap as chips. I bet the medium would work for just the bare GR and nothing attached but don't hold me to that.
10-02-2018, 06:05 PM   #8
monochrome's Avatar
@victormeldrew
Kata ZP-5DL small belt pouch is a perfect fit for the GR / GRll and a spare battery. Barely know it is there when you run your belt through the loop, yet is always zipper accessible. Pictures #2 & #3 fell the story.
10-08-2018, 01:19 AM   #9
Master of the obvious
savoche's Avatar
@victormeldrew
Looks nice. I have a different Kata bag; it fits fairiy comfortably but has no room for extra batteries: DF-408 DL | Kata Bags
10-08-2018, 04:33 AM   #10
monochrome's Avatar
QuoteOriginally posted by savoche Quote
Good one! The vertical orientation seems convenient.
10-09-2018, 01:02 PM - 1 Like   #11
OK...in the end my head was whirling from too many options, many discontinued, some only US market, then spent too much time with a tape measure peering at spec sheets and viewing too many reviews and wishing I could just try it on... So, I took my GR to my local large electricals place where they sell gopros and fuji compacts and a handful of bridge cameras and had a look in their bag aisle and found this:
Lowepro Apex 30 AW
Here it is on amazon: Lowepro Apex 30 AW Digital Camera Pouch - Black: Amazon.co.uk: Camera & Photo
The fit is SNUG. Just barely enough room for the camera length and width wise, but with enough depth for a spare battery or two and an SD card or two in the internal pocket. It's water resistant and tough and has a neck strap and a belt loop. It has a little padding, but not so much as to make it bulky, and it's discreet enough not to shout 'rob me'. So, if anyone is searching this in the future, I recommend it if that's what you're looking for.
10-13-2018, 03:05 AM   #12
johnha's Avatar
Lowepro Apex 30 AW
I was just about to recommend this pouch, I've used one for a while with my GR. As you say the fit is snug, but if you put the handgrip at the top, you can charge it with the USB cable without removing it from the case.
01-13-2019, 08:02 PM   #13
kyteflyer's Avatar
I'm using a Caselogic with a side zip to hold batteries and extra cards if required. Its very similar to this one Case Logic Point and Shoot Camera Case - Case Logic
LOL! Just noticed I am months late with a post to this thread. Oh well...
01-15-2019, 05:20 PM   #14
ChrisPlatt's Avatar
Manfrotto bought Kata and the pouches seem to be no longer available in USA.
I bought a Lowepro Dublin 30 pouch, which is just large enough for camera only.
Chris
01-30-2019, 08:49 AM   #15
The Think Tank 'Stuff It' is also worth a consideration.
I think the big question is if you are plan on expanding the add-ons with your Ricoh GR II.
- extra battery
- viewfinder
- tele conversions
digital camera, post, ricoh gr, thanks
Order Your Ricoh GR / GR II! Adam Ricoh GR 5 04-23-2019 07:35 PM
Purchased Metz 26 AF-2 for Pentax GR on advice of B&H; GR won't recognize it Mainerinfl Ask B&H Photo! 2 03-05-2018 05:33 PM
GR / GR ii - rough idea of shutter count/longevity? Conqueror Ricoh GR 3 04-20-2017 11:36 AM
All times are GMT -7. The time now is 06:53 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
