Originally posted by AgentL Here's the problem: GR cameras often develop a dust problem even if you handle and store them carefully. It's not a non-issue. You might get lucky, or you might not. Probably expect to get a sensor cleaning at some point, if not more than one. I've driven cars continually and in the last few years I've had dusty GR sensors and no flat tires.
With respect, though, you can't conclude anything based on such a small sample size - i.e. your own personal experiences, or even those of a handful of others. I don't own a GRIII, but I've several fixed lens digital cameras and none of them has suffered from dust on the sensor (even those where others
have experienced the problem), despite frequent use. Conversely, I've had two car tyre punctures in the last 30,000 miles of careful driving. That's just my experience... I can't conclude as a result that fixed lens cameras don't suffer from sensor dust (they
occasionally do), or that my premium brand of tyre is especially prone to puncturing (it's not).
Nothing's perfect. Fixed lens cameras
will get dust on the sensor from time-to-time. Tyres will get punctured. Some folks won't be affected by either, some will be affected by one or the other, and a few will be affected by both - perhaps multiple times. It's tempting to draw conclusions and cry "design weakness" when it happens to us because we try to make sense of things (that's human nature)... but by now - with the level of design that goes into these products - it's mostly just luck of the draw.
If, a couple of years from now, we have swathes of posts here from folks plagued by dust on the GRIII's sensor - and I'm talking about a similar number of posts to those reporting aperture block failure on the K-30 and K-50 (a very real problem) - then I'll concede there's an issue. Otherwise, it's just bad luck
