Originally posted by illdefined
the included Ricoh strap doesn’t even have a tightening slider
Originally posted by Sandy Hancock
A bit of bowstring serving would do the job nicely. I might get onto that myself.
The best GR strap by far is the GR one, once you have slid a tight piece of plastic or rubber tubing over it to act as a slip knot.
As illustrated below, you will need to thread it through a shoe lace first in order to slide it on. If it is too tight, heat (drop the plastic sleeve in hot water first) will help to soften it up.
My tube is thick walled 3.5 mm bore tube from an automotive shop, this is typically supplied to a length for use on fuel / emission or windscreen washer systems.
Once on, it will take some force to move it along (and that is ideal) but it will slide as the strap is smooth.
I did this as I and many users have found that without it the strap will fall off the wrist, and that is not ideal.
