Hello all,
Not sure whether this shouldn't rather be in the accessories forum, but I'm putting it here because my question is specifically for the various GR cameras.
I have used various tripod systems over the years, each with their specific quick release plates. The ones I used the longest are various tripods, monopods, heads with the Manfrotto RC2 system, until I switched to Arca Swiss compatible 3 Legged Thing more recently. Even though the quick release plates for the latter are smaller than the RC2 ones, even the smallest ones (in my case the one that came with my first PeakDesign Sling) are still gigantic on the GR III, and they cover the battery/card compartment.
So I'm looking for an alternative solution for my GR III.
- Most important is the small footprint of the quick release so it can stay on the camera for extended periods. Alternatively if is there is a system that mounts quickly without a plate that would be even better.
- I'm not sure about the size. On the one hand I would like sth with the same tiny form factor as the GR III, and I might even live with tabletop for some situations, but on the other hand I realize that in order to really provide a stable base for long exposures etc, I need sth more substantial... Alternatives for both are welcome...
Thanks in advance for sharing your experience!
grtz, Wim
