Originally posted by david94903
I'm new to world of GR cameras and recently picked up a GRIII. Really enjoying the camera. Under the Power Supply Settings, I have the Sleep Mode and the Auto Power Off Mode both set two one minute, which typically works as advertised. But I just picked up the GW-4 Wide Angle Lens and the GA-1 Lens Adapter. I discovered with the lens and lens adapter attached, the camera will not go into either Sleep Mode or Auto Power Off Mode. I actually did RTFM the manual, and though there are situations where the Sleep Mode and Auto Power Off Mode do not function, having the lens adapter attached does not appear to be one of them.
It's not really a big deal for me, as I'm in the habit of manually turning off the camera when I'm not shooting, but thought this was interesting. Anyone else have this experience?
david94903, This issue seems to not have been fixed yet. I recently purchased a GRIII and the GA-1 lens adapter. When the GA-1 adapter is attached both sleep and auto power off modes still do not work. When it first happened to me around 35 minutes had gone by before I noticed the camera hadn't powered down. The battery was drained overheating in the process. When I tested to confirm sleep/auto power off modes were not working within ten minutes past when it should have shutdown the battery starts overheating way beyond normal depleting itself in the process.
Can anyone else confirm the GA-1 has an issue with Sleep/Power Shutdown modes? This needs to be fixed as the issue itself is near a fire hazard the battery gets so hot.
I have the most recent firmware installed etc. I am surprised there hasn't been more comments concerning the use of the GA-1 lens adapter.
I tried using Ricoh's online inquiry system their reply was to send the GRIII to Precision which basically means Ricoh is oblivious to the issue.
