03-28-2020, 05:05 PM   #1
Auto focus/snap- please explain
Hi. I just started using Ricoh GRIII. I don't completely understand how auto focus and snap mode work. I assigned Fn button to AF and snap mode to 1m. Now when I want my focus to be on a distant subject I half press and focus on it, and it's supposed to be sharp. If I want to focus quickly on something within 1 m I full press focus button and the subject has to be in focus.
In this image I intended to focus on a man on a bench and I half pressed and I thought I focused. However, in a very bright day it's hard to see clearly the result. At home I discovered that the object is not in focus. I assume that I pressed Fn button and it switched to snap. Is tat right?
Can anyone explain this to me, please.
RICOH GR III  Photo
03-28-2020, 06:20 PM   #2
pschlute's Avatar
QuoteOriginally posted by irinaescoffery Quote
Two possible explanations.....
1. You did indeed select "snap focus" with a pre defined range of 1m (by mistake)
2. You correctly selected autofocus, but because almost half of your image is the grey structure (fence) on the left, the AF has focussed on that. AF is not capable of reading your mind and will focus on whatever it perceives to be the most logical target, in this case the fence.
This is a classic scene where single point AF (centred on the man) or manual focus is preferred.
03-28-2020, 07:17 PM   #3
Well, you might be right. I don't remember if it was a single point AF or AF.
My question is What if I assign other function to Fn button? (Let's say AEL). Will the camera always be able to focus correctly when I half press the shutter button?
Thank you for your reply.
03-29-2020, 02:35 AM   #4
pschlute's Avatar
I imagine it will, though I don't have any experience of that camera.
auto, button, digital camera, fn, focus, half, mode, press, ricoh gr, subject
please explain to me ccd vs cmos Desperado General Photography 3 06-29-2019 01:38 PM
AFA Focus Mode! What is it? And do I need it? Explain? BirdDude007 Pentax K-3 & K-3 II 9 06-23-2018 08:12 PM
Please explain telephoto 'power' aps vs ff lens Robboa Pentax SLR Lens Discussion 5 07-16-2011 10:12 PM
Please explain the difference in these 2 lenses J.Scott Pentax SLR Lens Discussion 2 12-09-2009 01:10 PM
Please explain a use case of sensitivity priority dardjiskien Troubleshooting and Beginner Help 9 11-30-2009 10:54 PM
All times are GMT -7. The time now is 04:17 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
