Originally posted by BigMackCam your replies come across as just a little curt
that's a shocker, what makes you think like that ?
Originally posted by BigMackCam What you can't necessarily expect is that other GRIII owners will have experienced the same problem
I don't expect others to share the experience. I titled 'caught on video' to provide a clear evidence that overheating that GR is prone is happening and if you never experienced that issue then you can see when and how it looks like
Originally posted by BigMackCam I'm assuming your tests are limited to just your own camera, and (b)
sure, you see one camera on video so it's the right assumption it is just my own camera; I declared on video that I am open to test more under different conditions
Originally posted by BigMackCam other owners won't have the same usage patterns.
yes, that's exactly what I wrote in the introduction
Originally posted by BigMackCam You also can't expect that everyone will watch and listen to every second of your video... Some will watch with no sound, others will skip through bits or even most of it for the "TL;DR", etc.
why would I expect that ? I can assume that there will be some viewers that are not interested about overheating but would like to see picture that is less than 1% different but 6 Megabytes smaller
Originally posted by BigMackCam reports of overheating suggests that this may not be a widespread problem with the camera design, given "typical" usage.
it is widespread; it is fact GR III might overheat and you are warned in the manual but the question is if your usage is getting the camera reach these critical temps; there shouldn't be 'typical' or 'untypical' usage problems because with previous models you could have used camera however you wanted and overheating wasn't happening
Originally posted by BigMackCam As it stands, your video is valuable as a comparison for other owners with their own experiences
absolutely and other owners can repeat my test in their own 'backyard'
Originally posted by BigMackCam By the way, welcome to the forums
I am long time member but I don't know what happened to my account so I had to re-register
---------- Post added 09-10-20 at 02:04 AM ----------
Originally posted by c.a.m I think your video is a pretty good presentation of your experimental set-up and your tests. I was able to follow along and understand your procedure and data.
thank you for your input
Originally posted by c.a.m Am I correct in seeing that the ambient temperature during the tests was in the range of 31 - 35 degrees Celsius?
yes but please understand that ambient has very minor effect on overheating; overheating is happening when internal temp is reach critical limit; I can do same test inside in cold place and overheating will happen but probably a little bit longer; I take pictures indoors and during winter time so overheating is not gone under these conditions but might take a little bit more time to 'reach it'; problem is with getting rid of this temp that sources from inside the camera; I can tell you that taking pictures with opened battery cover has some positive effect to managing temperature
Originally posted by c.a.m It's interesting that the specifications for the camera at the Ricoh website and in the operating manual do not explicitly indicate an operating temperature range for the overall camera
BTW same manual doesn't specify fps for continuous shooting
Originally posted by c.a.m Have you run any tests at a lower ambient temperature, say 20 degrees? Could you comment on your experience in using the camera 'in the field' at those lower temperatures?
sure I have plenty of video material (documenting overheating) from streets taken for example in November
Originally posted by c.a.m general engineering and design perspective.
that's interesting angle; they knew overheating will happen but designed camera this way
---------- Post added 09-10-20 at 02:05 AM ----------
Originally posted by aaacb I'm also not using the camera continuously for a long time, such as for time lapse.
funny that they implemented intervalometer knowing that overheating might be an issue
---------- Post added 09-10-20 at 02:22 AM ----------
Originally posted by stevebrot Welcome to the Pentax Forums!
It is a little unusual for a new member to lead with a strong criticism of the product
I am no new member but long time heavy user of GR line with probably one the highest 'mileage' taken with previous GR
Originally posted by stevebrot I don't do that style of work so it has never been an issue. I don't manage continuous activity at 34C very well and am likely to fail before the camera.
it is summer and test conditions were chosen to favor overheating quickly but in real life overheating happens no matter what ambient temp is; it might take 40 minutes but as well 90; there are so many factors
Originally posted by stevebrot It appears you have found a performance limit for that aspect of your camera. As noted in the video, the use case is unusual and not representative of what most people might do in actual shooting.
of course, this is proof of overheating video; it would be much harder to have someone following me for 90 minutes, recording video and waiting when overheating will happen; what I can and did was recording a video when in real life this happened; I have some of those where you see the camera doing nothing or little and overheating turning off the camera;
Originally posted by stevebrot From your account, this is a common issue for you and not something that Ricoh has been able to address through repair.
exactly; they know it will overheat so they did warning and turning off, if it's in manual then it is affecting all the cameras and IMHO it is fair to call it a common issue
I am not sure if that you could be addressed through repair, you would have to replace battery cover to different or place some heat absorption elements to get this under wraps
Originally posted by stevebrot There might be some way to attach a heat sink of some sort using the tripod socket.
yes but that will for studio shoots and not outdoors comfort
Originally posted by stevebrot Perhaps Ricoh might have a firmware update at some point that includes option for an audio alarm when overheating to avoid the abrupt surprise?
there are many different issues that could be repaired by firmware update but having reported these to Ricoh reps didn't make any change yet
---------- Post added 09-10-20 at 02:27 AM ----------
Originally posted by ne! I believe the OP’s aggressive reply to my post and others here is very telling.
if there is any aggression then prove it, if not why would you write something like that ?
Originally posted by ne! FWIW, this video was posted to the Ricoh forum at dpreview less than an hour before he came here to create a new account so as to post the same thing.
I would post instantly on 10 more forums if that would help getting the issue known and fixed; it is in Ricoh users interest to have camera that is not overheating no matter is stressed or not
Originally posted by ne! I’ll admit that this strikes me as self-serving
self serving ??? overheating while taking pictures is a marketing nightmare and IMHO camera shouldn't be released with such a 'feature'
---------- Post added 09-10-20 at 02:35 AM ----------
Originally posted by BigMackCam OP remains open-minded to the possibility that the limitation doesn't affect many people in typical usage scenarios, we're all good
OP wrote that in the introduction and summary of the video so I will repeat myself again; as long as your usage is not getting camera too hot (49-53 Celsius)
then you are safe but the purpose of the video is to show that Ricoh made a product that is forcing users to adjust their usage to camera limits; it wasn't the case with previous models; it's not the case with other manufacturers it is Ricoh GRIII that is overheating while taking pictures; no matter what you do with your GRIII (photos, videos, timelapse) overheating might happen and it is a real possibility so you are warned in the manual and at LCD
