03-10-2022, 04:02 AM   #1
Unregistered User
Guest
GR lll DNG files and Digital Camera Utility 5
I have a K1 and KP and when I open the files in DCU (v5.9.3) it shows jpgs and dngs - I do the same with the GR lll files and it only shows the jpgs, the dngs are greyed out...can anyone tell me why this is?
03-10-2022, 06:28 AM - 1 Like   #2
So far as I'm aware, Pentax Digital Camera Utility support for raw files is limited to Pentax cameras - not Ricoh. Indeed, if I remember correctly, only a subset of Pentax cameras are supported by it. It will read JPEGs from any camera...
03-10-2022, 06:38 AM   #3
Unregistered User
Guest
Ahhh...that will explain it then! Thank you, I guess I just assumed because they are the same company both both brands would be supported.
03-10-2022, 06:40 AM - 2 Likes   #4
Not a Number's Avatar
DCU 5x ships with the GRII but doesn't seem ship with the GRIII. Support of the GRII is probably why Ricoh dropped "PENTAX" from the name. The K-30/50 did not ship with PDCU/DCU either but rather a trimmed down version of SilkyPix. However DCU, AFAIK works, with files from the K-30/50.
03-10-2022, 10:26 AM - 2 Likes   #5
DCU will read any JPG but will only edit JPG files that include Pentax-specific EXIF
However, DCU is backwardly compatible with all Pentax DSLRs since the *istD
Probably part of the licensing arrangement with Silkypix that allows them to include a copy with every DSLR.
Similarly the RAW Converter software supplied by Samsung with their NX cameras was also Silkypix based … that will only open pictures taken with Samsung cameras.
03-10-2022, 02:15 PM   #6
QuoteOriginally posted by kypfer Quote
Thank you both... I've not done much with DCU beyond trying it out occasionally. For some time I was a dedicated Adobe Lightroom 6 user... now, mostly RawTherapee and Darktable with occasional use of Lightroom 6 when absolutely necessary (which isn't often, with Pentax at least). In the past I found DCU slow and clunky, but on my current machine it's reasonably nippy by comparison. I don't think I'll use it much, but it's nice to have another arrow in the quiver, so to speak...
03-11-2022, 12:35 AM   #7
Unregistered User
Guest
Thanks for the info - I mainly use DxO Photolab and Affinity but love to clog up my computer with any photo-editing software I can get, so had been messing around with DCU!
03-11-2022, 01:08 AM   #8
QuoteOriginally posted by CraigR Quote
This turned up on a local FaceBook group a few weeks ago … they send you a link to the program and a serial number ... seems legit but I haven't actually tried the program.
Luminar 4 (Full version) *free* from this link.
https://skylum.com/chip-luminar4?clickid=X05R39zvIxyIUgg3y0R%3AYzP4UkG1YAx%3AnU6FRo0&irpid=121977_LINK_cpa&aclid&platform=IR&fbclid=IwAR2pAToQ6tCON7iiC1IFFNU_lbWgCN0qT1rli_zqNYrAeZpG9hkltYVNeQg
03-11-2022, 01:41 AM   #9
Unregistered User
Guest
Thank you very much! I just downloaded it but need to add the email I bought it with to be able to use it...or just use the 30 day trial mode.
03-11-2022, 02:30 AM   #10
If you're considering other raw converters, I would seriously recommend the open source, completely free RawTherapee. It can seem a bit daunting at first, but it's really worth learning to use it - even just the basics, which will be enough for most of what you'd want and need to do. I have numerous raw converters, and RawTherapee is the one I choose most of the time...
03-11-2022, 03:35 AM   #11
Unregistered User
Guest
Thanks Mike. Yes, I downloaded it a few weeks ago (because I read that it shows the separate images when pixel shift is used) but haven't really looked at it properly yet. I am using DxO Photolab to tweak/process the raw files (their denoise is great) followed by Affinity to create the jpgs from the dngs and am finding that a good combo for me.
03-11-2022, 06:59 AM - 1 Like   #12
If you want to use raw edit and simulate in-camera color, you can consider this Lightroom plugin : PerfeFilm GR 😊 The color seems to be very good reproduced.
03-11-2022, 09:10 AM - 1 Like   #13
When I downloaded the program from that link it was totally free, a serial number was included in the associated e-mail … maybe it was a limited time offer … sorry
camera utility, digital camera, dngs, files, gr, gr lll dng, jpgs, lll dng files, ricoh gr
Digital Camera Utility 5 DNG conversion gkgkricoh Digital Processing, Software, and Printing 8 12-02-2021 05:36 PM
Noob question-K3 lll Digital Preview? LostViking Pentax K-3 III 11 06-24-2021 09:52 AM
Problem with Ricoh Digital Camera Utility and K3 iii DNG K2 to K50 Troubleshooting and Beginner Help 7 06-15-2021 07:26 AM
Does the new Ricoh GR lll get dust on the sensor ? lesmore49 Ricoh GR 56 11-14-2020 05:25 AM
Pentax Digital Camera Utility 4 changes to raw files disappear 7samurai Troubleshooting and Beginner Help 4 05-25-2011 05:05 PM
All times are GMT -7. The time now is 01:36 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
