01-17-2012, 11:17 AM   #2161
Oog
Compression or the appearance of "compression" or expansion has something to do with distance ratios. Take a head and shoulders shot - one with your favorite 85mm, and one with 24mm, on your favorite 35mm film. **Move close with the 24mm to match subject size.** The face and nose appears flattened with the 85mm. The nose looks longer and the hairline appears to recede with the 24mm.
Why?
For 85mm, the distance ratio of nose to camera:hairline to camera is close to 1:1.
For 24mm, the distance ratio of nose to camera:hairline to camera is considerably less than 1:1
We would normally refer to this apparent lack of compression when using the 24mm in this case as "subject distortion" though that is relative. Go stare at someone's face from 3 inches away and you'll see "distortion" too.
(and yes, I got the concept of distance/perspective 15 years ago....)
01-17-2012, 11:29 AM   #2162
Pentaxor's Avatar
QuoteOriginally posted by Oog Quote
Why?
We would normally refer to this apparent lack of compression when using the 24mm in this case as "subject distortion."
with regards to the topic of equivalence, the only factor that would remain equal is exposure. f1.2 would still be f1.2 and f2.8 would still be f2.8 regardless of whatever camera size sensor the lens is fitted at.
trying to equal the other factors would result to compromises.
equaling the FOV would still result to DOF difference. cropping the image from two different lenses could lead to less resolution from the shorter focal length lens and would still show DOF difference. compression would take place if focus distance is made a compromise.
equaling the DOF would mean difference in focal length, which means loss of FOV flexibility when shooting or shooting distance flexibility.
we try so hard on trying to equate two different systems. I'm not saying it is not achievable. it is achievable, to a certain extent, but as of the moment, with the present lenses that are available and the nature of the lenses themselves, there will always be compromises involved.
there is no real and perfect equivalent lens like the FA31 for the APS-C. no equivalent for the 50/1.2. nor the 85/1.4. all these would result to compromises like FOV (cropping), DOF difference and compression (focus distance involved). again the only thing that doesn't change is exposure.
01-17-2012, 12:41 PM   #2163
Aristophanes's Avatar
QuoteOriginally posted by Pentaxor Quote
we try so hard on trying to equate two different systems. I'm not saying it is not achievable. it is achievable, to a certain extent...
Yes, but is it discernible?
That's the question.
We do look at photographs, right? The difference between f/5.6 on APS-C and f/8 on 35mm is hard to distinguish.
Going down a rabbit hole here.
01-17-2012, 12:53 PM   #2164
eddie1960's Avatar
QuoteOriginally posted by Aristophanes Quote
You mean aside from the FOV difference of course which is pretty damn dramatic if you ask me.
and of course the difference in apparent compression ..... and all the other stuff argued in the last 4 or so pages.
I'm generally in Falks court in this discussion, personally i don't care who makes the camera but i think someone could build a better design than the existing models, and Pentax is great at getting the best out of a design and could well build a nicer FF than canikon do. If they made it as appealing as the K5 has been to canikon users then we may see more migration towards Pentax
01-17-2012, 02:29 PM   #2165
jsherman999's Avatar
keeping FOV the same?
Did you really mean to say this? Because if we're talking about keeping FOV the same, then f/5.6 on aps-c and f/8 on FF should give you images tha look exactly the same with reagrds to DOF! (or within 1/3 stop.) So, yes, f/5.6 on aps-c and f/8 on FF is hard to distinguish, as described by equivalence.
f/5.6 on both aps-c and on FF would be easier to distinguish, the aps-c shot would have 1.3 stops more DOF. It's even easier to distinguish at the higher apertures at more distances to subject - f/2.8 on both formats, for example.
It really is the same rabbit hole that's been explored over & over & over again, I agree with that.
01-17-2012, 05:12 PM   #2166
Pentaxor's Avatar
I forgot to mention the scenario between DOF equivalence with regards to aperture speed. if such DOF adjustment is made, the APS-C loses some light as well by stopping down. again, compromises.
probably next time some people would argue how they can always increase the ISO. ahhmmmm, as mentioned, you just change the ISO which is a compromise.
01-17-2012, 05:42 PM   #2167
Mareket's Avatar
You need a full frame camera if you want one. If not, APS-C will never let you down. If you believe full frame cameras will make your pictures better then you're sadly mistaken.
Pentax haven't got a single model out that anyone REALLY wants, unlike the new Fuji or D4. Until they release a desirable camera then they're never going to do well. The Q was an excellent but half hearted attempt, and the K-5 masterfully conquers APS-C but it's not remotely exciting. The D3S had class leading speed, the D1X has the highest fps rates, the Fuji cameras have beautiful designs, and all have huge price tags. Pentax need to pick a niche to master and whack a huge price tag on whatever comes out. The Q mastered size, but wasn't elite or expensive enough.
Methinks
01-17-2012, 06:00 PM   #2168
falconeye's Avatar
No, we don't try hard to do so. It's a simple scale invariant, one of the most basic concepts physics is built upon.
And it just is the most basic level of understanding required to understand the impact of sensor format. Without it, any thinking must remain fuzzy. Trust me.
01-17-2012, 06:06 PM   #2169
Why? If ISO 800 is now as clean a shot as ISO 400....?
Now you see how the marketing people think and why sensor ISO advances change all the rules.
The differences are most noticeable at the ends of the spectrum where the least shots are taken.; they are least noticeable where the bulk of market appeal lies, and where the ISO change obviates.
01-18-2012, 07:57 AM - 4 Likes   #2170
fikkser's Avatar
Is any of your comparisons relevant? FF lenses should be used with FF cameras, putting them on aps-c is a compromise in every way.
How many of you have actually tested your glass on both APS-C and FF?
The EOS 5D gave my Takumars new life. I can now use them as they are ment to be used, putting them on aps-c again is not going to happen. After using 5d the k-5 viewfinder feels like a long thin tunnel - it sucks!
If you like me want sharpness and short DOF you "need" FF. If you want shortest possible DOF with a 50 1,4 or whatever lens on APS-C you'll use it in 1,4 and it won't be sharp enough. On FF you can stop down, match the DOF of APS-C and get better sharpness. It would be crazy to make expensive fast glass for aps-c when you can make a more expensive FF body with cheaper glass that will perform the same or better.
I use my AF-lenses on k-5 and put my takumars etc. on the 5d. Great combo, but a Pentax FF - mirrorless or dslr would be perfect.
01-18-2012, 11:11 AM   #2171
markku55's Avatar
QuoteOriginally posted by fikkser Quote
Wonderfull, I like this, +1
01-18-2012, 12:48 PM   #2172
Luminous landscape
Cheaper glass?
And exactly how much cheaper is the Canon or Nikon FF glass right now?
This is *exactly* why FF glass for all the brands (Sony-Zeiss, Canon, and Nikon) are so pricey.
That's the premium product, not the cheap one.
It was in the 1970's and 80's as well, when all those 50/1.2's and 1.4's came out for that "soft focus" look.
01-18-2012, 01:31 PM - 1 Like   #2173
maxfield_photo's Avatar
Equivalency arguments are so entertaining, there are so many ways to think about it, and it's clear that everyone understands the principal, yet if you don't state it in the terms in which the other person thinks about it, you're wrong. Gotta remember to say things like "for a given subject", or "at a given distance". or "for a given print size". Where's my popcorn?
01-18-2012, 02:04 PM   #2174
Asahiflex's Avatar
I'll keep my mouth shut until the CP+ show in Japan, early february. I guess everything has already been said and done; now let's just sit back, relax and wait.
01-18-2012, 02:36 PM   #2175
Zygonyx's Avatar
Yes, and let's hope Ricoh will bring more than pop corn to this show.
aps-c, bodies, body, dslr, full-frame, lenses, lineup, pentax, system, users
Full frame pentax cem.kumuk Pentax DSLR Discussion 11 11-12-2010 03:13 PM
Pentax and Full Frame... Shutter-bug Photographic Technique 60 11-03-2010 10:03 AM
Pentax A 50/1.2 on Full Frame aegisphan Pentax SLR Lens Discussion 23 10-28-2010 04:16 PM
News Regarding Advertising on PentaxForums.com: An Official Statement Adam Site Suggestions and Help 5 03-24-2010 07:37 PM
Official: New DSLR Body is Coming; Full Frame Model is Under Planning! RiceHigh Pentax News and Rumors 78 08-04-2008 06:18 PM
All times are GMT -7. The time now is 10:46 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
