07-10-2012, 05:24 PM   #3061
QuoteOriginally posted by NickLarsson Quote
Neophyte question : is a lens as thin as the DA40 XS would be possible on other mounts ?
Lenses with focal lengths close to the flange focal length (actually slightly shorter as the back of the lens extends inside the mount) can be made very small, because they don't need retrofocus groups (for shorter focal lengths) or telephoto extension (for longer focal lengths). 40mm happens to fit right in this sweet spot for the K-mount (having a not particularly fast aperture doesn't hurt either).
So yes, in theory they can make lenses as small, but the focal length for the theoretical minimum size lens will vary between mounts. Notice all the pancake lenses for mirrorless cameras have short focal lengths clustered near their flange focal lengths.
Of course you also have to consider whatever complicated designs are needed for various focal length/aperture/sensor size combinations.
07-10-2012, 06:22 PM   #3062
QuoteOriginally posted by Cannikin Quote
Nikon could probably do it. Canon's new 40mm "pancake" is considerably thicker, probably because all Canon AF lenses need to have a built-in focusing motor.
Of course, neither of these would be stabilized.
07-10-2012, 06:25 PM   #3063
NickLarsson's Avatar
It's clear, thanks
07-11-2012, 06:18 AM   #3064
eddie1960's Avatar
QuoteOriginally posted by ElJamoquio Quote
Those lenses on a FF camera would be about 1.8. The front element is about the same size as one that's 1.8.
You should use the canon 0.95 or Leica 0.95 (don't remember the exact numbers) and start from there. You're talking serious cash, several thousand is about right.
the Leaica 50 0.95 has a retail of $10000, and a 1 year wait list. Because of this copies on the used market regularly go for $14000. Insane huh. The Canon was also a rangefinder lens, using the ridiculously rare S mount, though most about now have been converted to M mount. Freakin huge lens too. these are all at least 37 years old (the & series RF was dropped in 75) they go from $1600-$4000 depending on condition and your luck on ebay
07-12-2012, 08:51 AM   #3065
OK, not long ago I was strongly rejecting the possibility of an M-mount DSLR, as this rangefinder mount does not leave the required mirror clearance (why would it? It's a rangefinder...)
And few minutes ago I was reading this:
Fujifilm gives more details of X-system lenses and accessories: Digital Photography Review
"The adapter includes a dual-function gauge so that you can check that the lens doesn't protrude too far into the body[...]". So even a MILC can have such troubles with M-mount lenses.
07-12-2012, 09:53 AM   #3066
eddie1960's Avatar
the m mountor also includes a guage. it's for the lenses like the Jupiter 12 35mm which have large protruding rear elements (the Jupiter 12 does fit (just) on an M mountor which makes me want one (somewhat). If they had a FF mountor I would jump on it. On film the Jupiter 12 is my favourite RF lens
07-12-2012, 11:28 AM   #3067
RonHendriks1966's Avatar
Well that is the punishment for starting with something new and then try to attrackt users with an adapter I guess.
It would be smart to start with a M-mount updated with contacts that just fits all M-lenses to start with.
07-12-2012, 11:47 AM   #3068
eddie1960's Avatar
QuoteOriginally posted by RonHendriks1966 Quote
the big issue is actually with the older LTM lenses vis the m adater for them. The designs like the jupiter 12 are copies of the CZ Biogon 35mm from pre WW2 and have a huge protruding rear element (there are other RF lenses with this type of design as well.)
you can't actually use the Jupiter 12 on an M9 which is native M mount apparently. it works ok on the film cameras. and the GXR M Mountor
Edit a picture may help
07-12-2012, 02:00 PM   #3069
Anvh's Avatar
Nope, I'm not. And I never said the 645D is competing directly against FF, don't make things up. What I claimed is that medium format is their pro solution (or at least as pro as it gets) - and that's a fact.
But you gave that answer to the question, what could pentax do when they want to compete directly with FF of canon and nikon.
You indeed said that the 645D was Pentax pro solution, but since you gave that answer to that question it's very natural to draw the assumption you meant it qould go up against the FF of nikon and canon.
07-12-2012, 02:03 PM   #3070
Anvh's Avatar
mhmm indeed but the fact is that we don't have anything that comes close to that...
07-12-2012, 02:05 PM   #3071
Anvh's Avatar
If i look at Carl Zeiss something that comes very close to Voigtlander for example the CZ 85mm and compare it to canon nikons 85mm i don't see the differnce that much.
07-12-2012, 02:48 PM   #3072
QuoteOriginally posted by Anvh Quote
You really have to work on accuracy.
Okay answer me this, if pentax won't make a FF camera but they do want to compete in the professional market how are they going to do that?
This is actually what started it all, lets see if you can up with an answer.
How I answered:
Medium format; that's their professional system.
Which, FYI, is a valid answer - the professional market not being limited to the small format - and exactly the path Pentax is following.
07-12-2012, 03:53 PM   #3073
But dont you think that 645D vs 4D etc. is not a valid comparison, because it addresses different target groups? Dont you think that "competing" in the "Pro segment" might include this (sports, action, lifestyle) shooting ? Havent seen a paparazo with a Hassi etc.
07-12-2012, 04:26 PM   #3074
Is English your primary language? I don't understand what you're trying to convey to me.
07-12-2012, 07:30 PM   #3075
QuoteOriginally posted by Mehlsack Quote
Maybe because they don't need it. Perhaps Pentax, with their 645D system, really does not want to be in the same "pro" field that Canon and Nikon dominate - like you said, sports/action/lifestyle, which some can actually be fulfilled by a good APS-C system.
From this point of view I understand Pentax's stand on providing gear for pro's. It's the gearhead in me that wants that Pentax 35mm to come out. =))
Though well, if chips do get cheaper in the future we will see one from Pentax. but maybe not this year.
aps-c, bodies, body, dslr, full-frame, lenses, lineup, pentax, system, users
Full frame pentax cem.kumuk Pentax DSLR Discussion 11 11-12-2010 03:13 PM
Pentax and Full Frame... Shutter-bug Photographic Technique 60 11-03-2010 10:03 AM
Pentax A 50/1.2 on Full Frame aegisphan Pentax SLR Lens Discussion 23 10-28-2010 04:16 PM
News Regarding Advertising on PentaxForums.com: An Official Statement Adam Site Suggestions and Help 5 03-24-2010 07:37 PM
Official: New DSLR Body is Coming; Full Frame Model is Under Planning! RiceHigh Pentax News and Rumors 78 08-04-2008 06:18 PM
All times are GMT -7. The time now is 03:12 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
