06-15-2012, 11:44 AM   #661
RXrenesis8's Avatar
QuoteOriginally posted by thibs Quote
Mmm I still think aperture simulator should be there though, at that price I'd be pissed.
What is an aperture simulator? Are you talking about a DoF preview lever/button?
06-15-2012, 11:54 AM   #662
eddie1960's Avatar
QuoteOriginally posted by RXrenesis8 Quote
if that is what he meant then of course it is on all the top level pentax models
06-15-2012, 01:58 PM   #663
Anvh's Avatar
QuoteOriginally posted by ElJamoquio Quote
To 'really get something'? The DA 40mm is what, $350 or something right now? How much does a 24mm f/1.8 APS-C cost and weigh?
I already explained myself to Eddie, i wasn't looking at the primes but the standard f/2.8 zooms
Besides i'm looking in a different market then you're, the EU.
06-15-2012, 06:32 PM   #664
OK - but the new Nikon 24-85 should be lighter than the 16-50...
06-16-2012, 08:08 AM   #665
Anvh's Avatar
Maybe but it isn't a constant aperture so i wont consider it since having a constant aperture is handy for flash photography.
06-16-2012, 12:56 PM   #666
A pentax-designed 24-70 f/4.5 would be lighter than the equivalent pentax-designed 16-50 f/2.8. Whether or not Pentax would actually think there's enough of a market for the f/4.5 is in doubt, though.
06-16-2012, 01:46 PM   #667
thibs's Avatar
No, I mean Pentax should uncriple the mount and offer proper CW metering (or even better matrix metering, it is possible, Nikon F6 does it) with K and M lenses. For that price, they shoud do it. For 1500$ though I understand why they don't (I don't agree but I see why they wouldn't).
06-16-2012, 04:43 PM   #668
drougge's Avatar
QuoteOriginally posted by eddie1960 Quote
Nikon lenses need to have had the Ai upgrade for them to work. that is the equivalent of using an A lens. Pentax has no issues with A lenses AFAIK. That stupid metering tab was a fugly solution IMO
An A lens allows the camera to control aperture, an AI lens just tells the camera what aperture it's set at. Same as K and M lenses. The most important difference though that any F mount lens can be (reasonably) easily upgraded to be an AI lens, a pre-A Pentax lens can not be made into an A lens (except in rare cases, or with difficult mechanical modifications).
The Nikon worlds closest equivalent of A lenses is AI-s.
06-16-2012, 05:54 PM   #669
Anvh's Avatar
Actually it would be the same because bout the same amount off glass goes into it, sure the 24-70 is of simplere design so slightly lighter but the 70-200 will be heavier then the 50-135 so all in all there is no gain or lost.
Beside i would wish for APS-C mount to address some limitations but i doubt we will ever see that
06-16-2012, 07:38 PM   #670
QuoteOriginally posted by Anvh Quote
I think a 70-200mm f/4.3 is/would be lighter than a 50-135 f/2.8. The canon f/4 is about 3% heavier than the Pentax 50-135 (somthing like 705 grams and 685 grams), and of course Pentax lenses usually run a bit lighter than Canon.
With the ability to crop , a 70-200 f/4 with FF would be like having two lenses in one... in APS-C equivalent a f/4 would be like having a 50-135 f/2.8 AND a 70-200 f/4 lens in one lens.
06-17-2012, 03:30 AM   #671
Anvh's Avatar
No it won't because because you also adjusted the aperture so the amount of glass going into it is roughly the same, only the amount of elements and such will give the differnce and since you need a larger image circle with FF that would also add slightly more glass. So lets say in use the weight is the same.
And you proof so with your own example and Pentax are lighter because they are APS-C lenses.
That's a bit of a strange thing to say because DOF isn't everything, what about light gathering? sure you can bump up the ISO of FF but that's not helpful for image quality because you will loose all advantage you had over APS-C so why bother?
06-17-2012, 10:04 AM   #672
06-26-2012, 11:15 AM   #673
Aristophanes's Avatar
If you want a good summary about sensor cross-licensing design and fab, the Thom Hogan June 22/2012 mini-article is very good:
Thom Hogan's Nikon Camera, DSLR, Lens, Flash, and Book site
There is so much cross-licensing going on these days as sensors have not yet achieved commodity maturity that it makes sense for foundries like Sony to get locked-in supply deals with major customers who also supply licenses, like Nikon.
It is pretty clear that Nikon has been driving a lot of the advances in FF tech, and that Sony fabs the sensors in Nikon's FF flagships. But Sony also wants some of Nikon's tech post-Alpha A900/850 runs. It's probably far cheaper for Sony to license from Nikon but then give Nikon exclusivity of supply for a period of time on an equitable basis for both. This is common in lots of industries.
From what Thom says and from others in the industry , it is simply not possible to buy a sensor off the shelf. You need to get in at the original design level. Pentax, Nikon, and Sony share APS-C sensors and each appears to do this uniquely off the nearly same sensor.
To a limited degree (and with obvious decaying shelf life at each product cycle) Sony needs Nikon and Nikon needs Sony. Do either need Pentax? Canon needs no one. Fuji needs no one. Leica needs someone else. Samsung pretends it needs no one.
06-26-2012, 12:05 PM   #674
jsherman999's Avatar
QuoteOriginally posted by Aristophanes Quote
From what Thom says ... it is simply not possible to buy a sensor off the shelf. You need to get in at the original design level. Pentax, Nikon, and Sony share APS-C sensors and each appears to do this uniquely off the nearly same sensor.
As Pentax-Ricoh could do with a FF sensor, bought/licensed from Sony and/or Aptina, or even another party.
Thom's article was interesting, but if you're trying to find a "Pentax simply cannot buy a FF sensor!" hint in there... You won't find it.
New customers are always needed, especially these days, especially ones the size of Ricoh, who has multiple existing and in-design products that could use product from a Sensor design/fab shop. Sony, Aptina, etc, have plenty of fab capacity and licensing leeway to answer Ricoh's call (if it every comes.)
06-26-2012, 12:25 PM   #675
Actually Sony is lacking in fab capacity. The only acquisitions of Sony recently is more fab capacity. The Sony retail ship is sinking but Sony Semi and Industrial has found its feet once it got over losing out to Korea on TV's. Sony is doubling down on fab capacity. They are by far the dominant supplier in the industry.
The Hogan point is that you really only source a sensor from design phase in, and you have to deal with multiple licensing issues, likely including those held by Sony and probably Nikon. That requires years of lead time. When Hoya closed the door that made it a timing issue for Ricoh. I suspect FF is in the works, but we are about 12-20 months from delivery. The specs and supply rumors from the Nikon camp have some weight, but not on price and timing.
24x36mm, aps-c, camera, capacity, company, d4s, dont, ff, followers, frame, full-frame, idea, im, iso, k-3, lens, lenses, letter, light, lw/ph, nikon, page, pentax, release, time, traffic
The full frame Pentax that never was dj_saunter Pentax DSLR Discussion 23 05-06-2011 04:06 AM
Pentax and Full Frame oppositz Pentax DSLR Discussion 58 03-18-2011 09:39 AM
Full frame pentax cem.kumuk Pentax DSLR Discussion 11 11-12-2010 03:13 PM
Pentax and Full Frame... Shutter-bug Photographic Technique 60 11-03-2010 10:03 AM
Pentax A 50/1.2 on Full Frame aegisphan Pentax SLR Lens Discussion 23 10-28-2010 04:16 PM
All times are GMT -7. The time now is 09:53 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
