Let's start with
the necessity to change the mount. There are two kinds of reasons to do that, technical and business; you're offering neither.
In the first case, you would have to show how the K-mount is technically inadequate, and be aware that I'd apply the same logic to the F-mount, since they're quite similar. Without that, we shouldn't even talk about "which mount" (no, few people desiring to use non-Pentax lenses is not a technical inadequacy of the K-mount).
The second case is even more interesting; with a DSLR market several times that of MILCs and with a higher average value, with both DSLR and MILC markets being highly competitive I'd like to see you explaining how a built-from-scratch system would be easier and more profitable than adding a DSLR to an already existing system (with a non-negligible user base). Good luck with that.
Are you talking about
Originally posted by Kunzite I'm not saying it doesn't, I'm asking what makes you so sure it does. It would need room for several contacts, and in a place where it wouldn't interfere with legacy M-mount lenses (probably not inside).
Different from your interpretation.
Interesting enough, the power contacts are inside, for K-mount (and other mounts); maybe there is a problem with shorting them, or exposing them to dirt? I cannot simply accept the assumption that it would work, sorry.
And again, you are avoiding the difficult questions.
How would the adoption of a heavily modification of the Leica M mount + fully K-mount compatible adapter (instead of the readily available K-mount) help Pentax in getting that FF out faster?
