04-15-2014, 10:04 AM   #1411
The gain between aps-c and ff is almost twice the gain between ff and 645d.
If one gain is marginal than the other one is marginal*1.3.
In practice the 645 will be sharper but slower and much more expensive. Surely worthwhile to some, but not a broad solution.
05-09-2014, 01:59 PM   #1412
My two cents...he
I just ordered a Pentax Full Frame Camera - the 645D.
I've been shooting with the K-3 for a month now. Brillinat camera - the best Pentax DSLR ever. Brilliant IQ. But for low light shots, the APS-C sensor is still too small/too noisy.
Being a recently retired architect I aim to make a bit of money by photographing. So I consider getsmall business. I never tried the 645D, so I'm really looking forward to giving it af good testdrive one of these days :-)
Regards
Jens
05-10-2014, 02:41 AM   #1413
QuoteOriginally posted by Photodana Quote
My two cents...he
Regards
Jens
The 645D isn't full frame it's cropped. It doesn't have a full frame MF sensor
05-10-2014, 02:43 PM   #1414
Pepe Guitarra's Avatar
QuoteOriginally posted by markac Quote
33mm x 44mm sensor is cropped? Uhmmm.
Isn't the FF sensor the one that measures 24mm x 36mm?
05-11-2014, 12:28 AM   #1415
Fogel70's Avatar
Full frame 645 format = 56x41.5 mm
Full frame 135 format = 36x24 mm
05-14-2014, 05:19 AM   #1416
SkilakDeZoo's Avatar
I have noticed that some people rave about FF because they think that MF is something in between APS-C and FF So, from my point of view FF refers to the coverage of a frame in the film era and as far as I remember 35mm (so called FF in digital) was called as Small Picture (translating from my native tongue). I think there was something even smaller called "Karat" by ORWO? or something similar, what was half of the 35mm but can be wrong. With no doubt a "FF" would be a nice addition to the Pentax sable but not a must.
05-14-2014, 06:58 AM   #1417
QuoteOriginally posted by SkilakDeZoo Quote
In the industrial context, Zeiss now calls it "Large image format"!
F-Mount Lenses | ZEISS United States
"Karat" was the AGFA name. ORWO used "Penti" later.
There were various lengths with the standard 24mm height: 36mm, 24mm, or 18mm.
SL System - Camerapedia
05-14-2014, 08:09 AM   #1418
QuoteOriginally posted by lytrytyr Quote
I guess, if Zeiss wants to call it as a Larg format then I think they can call it whatever they want but then it sounds that Medium Format is something in between
.. and adding, if a matrix covers the full frame of a Karat frame, then it should be called as well as a full frame, should not? I do not see the link FF=35mm?
05-18-2014, 06:05 PM   #1419
Pioneer's Avatar
I think it is a bit disingenuous to call larger than full frame "cropped."
Lets see now...24x36 vs 33x44. Which one did you say was "cropped?"
People have been trying to downplay 6x4.5 for years saying it was only a "little" larger than 35mm. Now they are trying to downplay the digital version.
Ah well...in this case I think that "cropped" is a lot better than "full" frame.
05-19-2014, 12:45 AM   #1420
Clavius's Avatar
QuoteOriginally posted by Pioneer Quote
The difference between 35mm and 645D is about just as little as the differnce between APS-C and APS-H.
Crop:
APS-C: 1.5
APS-H: 1.29
35mm: 1.0
645D: 0.78
So, whilst I don't agree, I can understand the reasoning of those people.
But the difference between APS-C and 645 is substantial. So as long as Pentax refrains from a 35mm and that gap remains, upgrading to 645 remains worthwhile.
05-19-2014, 02:04 AM   #1421
It's 'cropped' because it isn't full frame 645 Medium Format. If it was full frame 645 it would be 56x41.5 which is quite a bit larger than 33x44. So in effect you you get a similar situation using 645 film lenses on a Pentax 645 digital camera as you get using 35mm full frame lenses on an APS-C camera. Both instances can be undesirable.
05-22-2014, 09:09 PM   #1422
Pioneer's Avatar
I understand that the 645D sensor is not as large as the original 120 film frame. It is still 145 square centimeters of sensor to capture light. The full frame sensor is 86 square centimeters. It may not be quite as much as the film size was but it is still a considerable amount of additional sensor real estate. IMHO it is well worth it.
Of course, YMMV
05-22-2014, 09:14 PM   #1423
Of course, YMMV
I think you mean 8.6 cm^2 and 14.5 cm^2, or the same as a 1.3 crop factor. Better, yes, assuming the lenses you want are available in 645.
05-22-2014, 09:23 PM   #1424
Pioneer's Avatar
QuoteOriginally posted by ElJamoquio Quote
Thanks for the correction, I must be about ready for bed.
And it certainly looks to me like the full frame is clearly the cropped sensor in this scenario, not the other way around.
05-22-2014, 09:39 PM   #1425
I'd be happy just calling them out by sensor area. Certainly would be better than arbitrary film sizes from 50-100 years ago.
24x36mm, aps-c, camera, capacity, company, d4s, dont, ff, followers, frame, full-frame, idea, im, iso, k-3, lens, lenses, letter, light, lw/ph, nikon, page, pentax, release, time, traffic
The full frame Pentax that never was dj_saunter Pentax DSLR Discussion 23 05-06-2011 04:06 AM
Pentax and Full Frame oppositz Pentax DSLR Discussion 58 03-18-2011 09:39 AM
Full frame pentax cem.kumuk Pentax DSLR Discussion 11 11-12-2010 03:13 PM
Pentax and Full Frame... Shutter-bug Photographic Technique 60 11-03-2010 10:03 AM
Pentax A 50/1.2 on Full Frame aegisphan Pentax SLR Lens Discussion 23 10-28-2010 04:16 PM
All times are GMT -7. The time now is 07:24 AM. | See also: NikonForums.com, part of our network of photo forums!
