Originally posted by Pål Jensen I once saw a fantastic picture shot APS with Pentax 24mm lens at F:22 with flowers close to the front element and landscape and the mountains in the background; everything in focus.
Pål, you really stress the minimum aperture argument.
In this particular example, you are correct (not that I think the equivalent aperture of f/15 from an FF lens would have looked
that different ...). But correct is correct.
Nevertheless, let's also look at the reason why you are correct...
It is the somewhat arbitrary availability of lenses for the various formats, i.e., their properties.
E.g., look at 70mm on APSC vs. 100mm on FF. The FF lens stops down to F32 while the APSC lens only stops down to F22. Now, there is no difference in the photo anymore.
This is so because both 70mm/22 and 100mm/32 are a 3mm apertures. And e.g., if an 24mm/22 or 1mm aperture can be made (as showcased by your APSC lens), then obviously a 1mm aperture or F32 can be made for the equivalent 36mm lens too...
So, why isn't it made?
Very simple: lack of demand. Only very few people ever want to shoot at F32 or F45. Focus stacking is a much better alternative preserving more resolution.
This lack of demand means the market decided your theoretical advantage for APSC is considered irrelevant by vendors.
To be clear: This is a marketing division's decision only. There is no technical reason why the minimum aperture expressed in mm should be larger for FF, comparing two equivalent lenses. To make it larger saves a tiny bit of cost over the APSC lens only.
Second view about the tiny aperture argument:
F/22 on APSC or F/32 equivalent is F/4 for a mobile phone or F/5.6 for some P&S cameras or the Q. And because diffraction replaces the AA filter, you'll get superior image quality from a P&S then. So, if this particular use case is so important, I'll suggest you don't even use use APSC for it. It will disappoint in comparison. And don't believe APSC maintains any advantage in IQ over a P&S at tiny apertures. It doesn't, it is inferior in all categories, including noise, except if you use a longer exposure time on APSC, i.e., if you ave plenty of light or work from a tripod. Then you have a valid point though (except that then focus stacking may be preferrable).
Some more thought: there are screw filters with a hole to provide a tiny aperture (pinhole etc.) too. They work well with normal to tele lenses. Just like ND filters, they shouldn't be ignored in discussing the tiny aperture argument.
