Show Printable Version 70 Likes Search this Thread
06-18-2012, 08:55 PM   #196
I corrected my earlier mistake. The 1.5x factor is on the DIAGONAL, not the height|width. So an APS-C 16mpx sensor with the same pixel density scaled-up to FF would be 32mpx. APS-C is very close to 135/HF (half-frame) or 24x18mm, half the area of 135/FF at 36x24mm.
Um, all linear dimensions are scaled the same. If the aspect ratio is the same, then 1.5x the diagonal means 1.5x both the height and width.
Proof:
Pythagorean theorem: A^2 + B^2 = C^2 (where A/B are height/width and C is diagonal)
C = sqrt(A^2 + B^2)
(1.5C)^2 = (1.5^2)C^2 = (1.5^2)(A^2 + B^2) = (1.5^2)A^2 + (1.5^2)B^2
therefore:
(1.5C)^2 = (1.5A)^2 + (1.5B)^2
Just for reference the K-5's APS-C sensor is 23.7 x 15.7mm (roughly 24x16, a scaling of 1.5 in every dimension). 24x18 isn't even 3:2.
06-18-2012, 09:23 PM   #197
You lose nothing of the sort. Focal length is independent of sensor size.
You GAIN angle of view, but the central crop is exactly the same image you would have had with APS-C.
Yeah, but who has time to crop every photo - with the smaller sensor it feels like a bigger lens, and with resolution now its better than ever. If bigger is better, why isn't everyone shooting with the Pentax 645? and even this seems odd to me, but most of the new mirrorless systems are all based on an even smaller sensor.
06-18-2012, 09:35 PM   #198
Therefore:
Digital APS-C (k-5) = 23.70mm x 15.70mm = 372.09 mm2 = 3.72cm2
Digital 135 (say, theoretical k-3) = 35.55mm x 23.55mm = 837.20 mm2 = 8.37cm2, scaled exactly 1.5x for each linear dimension of k-5 sensor
Equivalent k-3 sensor at the same pixel density of a k-5's 16.28 MP sensor = 16.28/3.72 * 8.37 = 36.63 MP
Uncropped k-5 @ 16.28MP (16.08 MP effective) = 4928 x 3264 pixels at max. image size
Uncropped k-3 @ 36.63 (36.19 MP effective) = 7392 x 4896 pixels at max image size
06-18-2012, 09:53 PM   #199
QuoteOriginally posted by Mohawk Quote
OK just to be devils advocate - who needs a 36 MP image size? Maybe only a handful of professionals making huge prints at full resolution, but certainly no one shooting for magazines or newpapers. I mean you can get poster size prints and even larger that are very sharp from a 16 MP sensor. I can see where 18-24 MP sensors are uselful, but 36, and when is it going to stop? 5 years ago I read an artical where they compared a 16 MP image to the resolution of a medium format negative and it was almost (not quite) but almost on par. I don't blame people for wanting to use their full frame glass though, that is the best argument i can think of.
06-18-2012, 09:56 PM   #200
I like 36 MP because it has almost zero disadvantages compared to APS-C - I can still crop to a k-5 image.
I also like 24 MP because the files are slightly smaller. Both are ok with me.
06-18-2012, 09:58 PM   #201
builttospill's Avatar
QuoteOriginally posted by gtl Quote
To me FF means using my FA Limiteds the way they were meant to be used... and thats reason enough for me to go FF
Exactly. They were meant to be used with a camera having a large, bright optical viewfinder. Oh wait, were you talking about FOV?
06-18-2012, 10:03 PM   #202
I think 36mp would be ridiculous. It could also hurt sales of the 645D. I don't have a need for any more than 24mp, especially since my 10mp K10D has produced beautiful photos for bulletin/billboard ads.
06-18-2012, 10:14 PM   #203
Less MPs will do that most of the lenses are still usable. It is bigger pixel on sensor if is FF and less MPs so lenses with lover resolving resolution are perfectly fine on sensor like that . Most of ppl intend to use older lenses so 24 MP would be much better than 36.
06-18-2012, 10:40 PM   #204
QuoteOriginally posted by Williunck Quote
Maybe because it's $10,000 brand new... and around $7,000 lowest, prolly, second-hand. Well, the 645D, at least.
06-18-2012, 10:42 PM   #205
ogl
Banned
Therefore:
It seems to me 24 MP is sweet spot. I see at K-5 that the best apertures moved a bit close to wide-opened.
I really see that my FA*24 has the best apertures at f4-6.3 at K-5 and f5.6-8 at K200D.
24 MP is very good for FF. New sensor with not much MP could be the best mix of resolution/noise/DR. Remove AA filter and it will shine.
06-19-2012, 12:53 AM   #206
gtl
Lol. I could do with both.
QuoteOriginally posted by builttospill Quote
06-19-2012, 02:56 AM   #207
Manufacturers of RAM and hard discs
06-19-2012, 03:21 AM   #208
Well, I think the issue is that at 36 megapixels, full frame takes away nearly any benefit of APS-C. Any "extra length" APS-C gives to your lenses is based on increased pixel density, not on the cropped format. The only downside is that it slows down frame rate and fills buffers faster -- really, the D800 has an amazing sensor.
Really, megapixels isn't as big a deal right now as things like iso and dynamic range, but down sampling a high megapixel image often gives better results than an image shot at lower resolution in the first place.
06-19-2012, 04:32 AM   #209
QuoteOriginally posted by Alizarine Quote
Went to $6k after the D800 came out.
06-19-2012, 04:33 AM   #210
QuoteOriginally posted by TomTextura Quote
Well, for a while Samsung was rebadging Pentax cameras. Not sure whether that refutes or reinforces the not a "real camera" company claim.
Please, don't forgot about the smilie; I wasn't seriously claiming that.
Unlike when they were rebadging Pentax DSLRs (real cameras, just not Samsung's ), they seems to put some effort in their NX system. Strangely, though, they have almost as many gadget MILC things cameras as lenses. Electronic giant corporation line of thinking?
cameras, dslr, frame, full-frame, pentax, pentax full frame, rumor, rumors, sensor, sony
The full frame Pentax? slackercruster Pentax DSLR Discussion 18 02-13-2012 10:09 AM
The full frame Pentax that never was dj_saunter Pentax DSLR Discussion 23 05-06-2011 04:06 AM
Pentax and Full Frame oppositz Pentax DSLR Discussion 58 03-18-2011 09:39 AM
Pentax and Full Frame... Shutter-bug Photographic Technique 60 11-03-2010 10:03 AM
Pentax A 50/1.2 on Full Frame aegisphan Pentax SLR Lens Discussion 23 10-28-2010 04:16 PM
All times are GMT -7. The time now is 10:45 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
