07-04-2012, 01:27 PM   #451
Wired's Avatar
Thats why i love my old film bodies. I got a line on a sportmatic too that i may grab....
I kind of wish i was around in the 70/80's to have the simplicty of photography at the time.
To be able to have a DSLR FF K mount with only the features of my old film bodies (+ ability to use DA lenses and AF) i would be estatic.
But sadly people want AF points...movie modes...metering modes...coffee machines....and android appa built intp their cameras.
07-04-2012, 03:35 PM   #452
eddie1960's Avatar
QuoteOriginally posted by ihasa Quote
Yes I tried a Canon 1ds iii and found the vf only slightly bigger than my k7. There's another area a Pentax FF can distinguish itself.
The Canon owner refused to believe that my MX had a much bigger vf, which is why I'm taking it with me next time I see him. Aren't I sad LOL!
well pentax has said there is no reason ALL vf can't be 100%' so for FF think MX or better
07-04-2012, 03:38 PM   #453
A 100% FF viewfinder would be pretty damn sweet, and it would separate pentax from the crowd, too.
07-04-2012, 03:40 PM - 1 Like   #454
Transit's Avatar
Have you got a 50/1.2 to go with it ?
...suck his eyeball right out
Pete
07-04-2012, 05:17 PM   #455
KungPOW's Avatar
Viewfinders became smaller with the advent of autofocus.
Part of the light is diverted to the autofocus sensor, and to keep the viewfinder bright, they make the viewfinder smaller.
Don't expect to see an MX style viewfinder in a modern autofocus body.
07-04-2012, 05:18 PM   #456
KungPOW's Avatar
QuoteOriginally posted by ElJamoquio Quote
As far as I know, the K-7 and the K-5 both have 100% viewfinders.
Pentax is talking about all of their cameras having 100% viewfinders.
07-04-2012, 05:23 PM   #457
QuoteOriginally posted by eddie1960 Quote
100% in terms of magnification and coverage would be a dream to use! Such a feature really would catch the attention of many a photographer.
QuoteOriginally posted by KungPOW Quote
Viewfinders became smaller with the advent of autofocus. Part of the light is diverted to the autofocus sensor, and to keep the viewfinder bright, they make the viewfinder smaller. Don't expect to see an MX style viewfinder in a modern autofocus body.
I hope that's not a certainty.
07-04-2012, 05:23 PM   #458
You know what? I was thinking about magnification, not coverage (and I was thinking about FF). Never mind.
07-04-2012, 08:46 PM   #459
Kryscendo's Avatar
What exactly is magnification when it comes to viewfinders? I never did understand that.
07-04-2012, 10:49 PM   #460
KungPOW's Avatar
QuoteOriginally posted by Kryscendo Quote
Magnification is how big the image appears in the viewfinder with a 50mm lens set to infinity.
The old MX had a magnification close to 1 (I'll let someone else look up the actual number 'cause I'm lazy).
So with a 50mm on the camera, and both eyes open, the viewfinder image looks to match the size of the non-viewfinder image from the other eye.
The K1000 has less magnification, and the same effect can be achieved with the 55mm lens.
My F100 has a magnification of 70% of so, and it gets a one to one magnification with a 70mm lens.
My D300 gets a 1:1 image with a 50mm lens. But, when used with a 35mm lens (the actual "normal" lens for this body) it is only about 70% magnification. So, the reality is that even though it looks like it gets 100% magnification with the 50mm standard, because on the crop sensor, this lens is really a short telephoto. As I understand it this is why all the crop bodies can have magnifications close to 100%, and still have autofocus and bright viewfinders. Essentially they cheat with the 50mm lens standard when used to define magnification.
07-05-2012, 12:58 AM   #461
Kryscendo's Avatar
So why is it so hard to make a camera close to 1x Magnification? Sounds like 100% viewing angle is important but if the magnification is way off, that could be something too.
07-05-2012, 04:34 AM   #462
falconeye's Avatar
-> LumoLabs -- True reasons for Full Frame -- Whitepaper # 1.6. Viewfinder
btw, there is nothing special about 1x magnification. A viewfinder can be 1.5x as it can be 0.7x. But cost increases with perceived angle of view through the viewfinder (and the height of the eye point). This is well illustrated by wide angle scope oculars (eye pieces). Ironically, Pentax was considered one of the very best when it came to wide angle oculars (ask @jogiba). But I think Ricoh now closed that operation.
Perceived angle of view is proportional to:
Magnification x Coverage/100% / crop-factor
My MX has a stellar 0.92x for the perceived angle of view. But I always found it difficult to oversee the entire viewfinder image (I wear glasses). Back at that time, I considered that to be a weak point of the camera. (Now I know, the weak point is its eye point isn't high enough). The eye point is the maximum distance between eye piece rear element and pupil which allows the entire field of view to be projected into the eye.
This is the smc Pentax XW 10 eyepiece with 359,- USD MSRP:
-> PentaxWebstore.com:Eyepiece smc Pentax XW 10 (1.25" tube) Eyepiece smc Pentax XW 10 (1.25" tube)
"this eyepiece features a 70 degree field of view and 20mm eye relief" (eye point).
70 FoV corresponds to a perceived angle of view of 1.50x! This shows what is feasible from a purely technical point of view.
Current VF are a cheapo compromise and I really hope to see exchangeable viewfinders again.
Wrt eye points:
Nikon F4: 22 mm
Nikon F100: 21 mm
Nikon D3, D700, D4: 18 mm
Nikon D800: 17 mm
Canon 5DmkII: 21 mm
One more thing: large viewfinders (with good eye relief) are large (one reason why cameras with no flash have better eye relief). It isn't reasonable to ask, at the same time, for the most compact FF and for the best VF, in one camera. You must make a decision!
07-05-2012, 04:35 AM   #463
eddie1960's Avatar
Magnification is an issue. a number of the current FF cameras are 100% coverage (which is nice to have) but in the .74x magnification range which makes them only marginally better than the apsc ones at 100% but .94-.97x or so (like a k7/k5/k30)
Np reason a FF finder can't be 100% and .97 x though - the mx was in that range, the higher end Ff are (but they need to cripple things to make people want to move up)
Pentax if a Ff comes will have no need to cripple the VF to support multiple models
07-05-2012, 04:41 AM   #464
Asahiflex's Avatar
The mythical Pentax FF should and must have the best optical viewfinder, period.
(People who don't care about FF: please never look into a ME or ME-Super viewfinder. Otherwise your day will be completely spoiled.)
07-05-2012, 05:01 AM   #465
falconeye's Avatar
QuoteOriginally posted by Asahiflex Quote
MX VF is significantly larger
cameras, dslr, frame, full-frame, pentax, pentax full frame, rumor, rumors, sensor, sony
The full frame Pentax? slackercruster Pentax DSLR Discussion 18 02-13-2012 10:09 AM
The full frame Pentax that never was dj_saunter Pentax DSLR Discussion 23 05-06-2011 04:06 AM
Pentax and Full Frame oppositz Pentax DSLR Discussion 58 03-18-2011 09:39 AM
Pentax and Full Frame... Shutter-bug Photographic Technique 60 11-03-2010 10:03 AM
Pentax A 50/1.2 on Full Frame aegisphan Pentax SLR Lens Discussion 23 10-28-2010 04:16 PM
All times are GMT -7. The time now is 12:59 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
