06-15-2012, 01:14 PM   #46
parsons's Avatar
More Pentax full frame DSLR rumors | Photo Rumors
look what you've done now!
06-15-2012, 01:26 PM   #47
parsons: ouch! now that may change the game plan if those rumors are real, as I don't think these are supposed to be leaked...
06-15-2012, 01:32 PM   #48
hcarvalhoalves's Avatar
A FF K-01 would be the most useless camera ever.
A compact FF DSLR, on the other hand, is pretty much a dream come true. Nowadays you either put up with all the bulk or buy expensive rangefinders if you want a big sensor. There's a niche awaiting to be filled.
06-15-2012, 01:35 PM   #49
jsherman999's Avatar
QuoteOriginally posted by parsons Quote
I think that might be a case of circular rumour-mongering.
And this looks so very fake - looks like someone used MS paint to place the "K-3" there
EDIT: indeed, that's the same image that appeared on 4/1.
06-15-2012, 01:47 PM   #50
RonHendriks1966's Avatar
QuoteOriginally posted by hcarvalhoalves Quote
Well I disagree, since that serves a different market and is very cheap to introduce next to the FF dslr. I did some studiowork last week with K-01 and having a dslr is not nessacery, since that mirrorless can do the trick. That would be the same for a pro full frame mirrorless.
06-15-2012, 01:50 PM   #51
parsons's Avatar
the k3 will probably look quite a bit like that besides the mirror size and whitebalance symbol
they wont name any FF k-3. that will just confuse everything even more than it is already
06-15-2012, 01:54 PM   #52
parsons's Avatar
QuoteOriginally posted by RonHendriks1966 Quote
Well I disagree, since that serves a different market and is very cheap to introduce next to the FF dslr. I did some studiowork last week with K-01 and having a dslr is not nessasery, since that mirrorless can do the trick. That would be the same for a pro full frame mirrorless.
I think that if there were the possibility to put fast ff glass inside the mirror box then it would be ok. my fear is that it would have to be relatively slow to fit,( what with all the other stuff, sdm linkage for example, might be wrong about that though) so there wouldn't really be much advantage.
06-15-2012, 01:58 PM   #53
QuoteOriginally posted by aurele Quote
Another rumour ?! Sooooo cool ! let's talk about this on hundreds of pages !
WOUHOUUUU !
Its like a soap opera!!!
All we need is dramatic music and then the show to abruptly end before it ends with a message that says 'tune in next week for the conclusion...'
06-15-2012, 02:02 PM   #54
I heard from an unreliable source two days ago saying Sony has agreed to let Pentex use the FF sensor of Sony A99.
Again, as I posted here couple of months ago here, a much more reliable source said the Pentex FF camera will be released during Photokina this Sept.
Let's see. Anyway I don't have any interest to buy a full-frame in couple of years. It is just too big to carry around for me.
06-15-2012, 02:07 PM   #55
parsons's Avatar
QuoteOriginally posted by feishui Quote
who are these sources? FF at photokina has been the rumour since for ever.
its going to be the smallest FF apparently.. so will probably be about k5 sized is my guess/little bigger.
better not be the size of that k-1 prototype anyway! that wasn't a brick (k-01?) more like a breeze block... far far too big!
06-15-2012, 02:20 PM   #56
Well even not why I would want it, but the mirrorbox from a ff camera is bigger then inside the K-01 that has a smaller aps-c sized box. So maybe a good kitlens could be made for it.
Difference between the both could also be in other manors like electronics. The mirrorless with only a single PRIME M engine (jpg 3 fps and RAW again only 1 fps) while the dslr could run on a dual core with more power and very different and faster AF, housing like K-01 and the dslr in a robust magnesium alloy. The price difference could well be a few hundred $ and the mirrorless will be smaller.
Look at the both:
http://camerasize.com/compare/#285,187
Both K-01 and K-5 have to grow to house the larger sensor, but still the mirrorless will be the smaller one.
06-15-2012, 02:30 PM   #57
mecrox's Avatar
QuoteOriginally posted by yen800 Quote
you are correct Alizarine, but will ricoh invest on FF that much to get sony sensor asap? I don't think so.... and I heard K-5 successor is currently placed on hold too...
Uh-oh, that's rabbit in the headlights. If they don't do both, even if the new K5x is taken down a notch, they will be stuffed, imho. At the mo there is just the K-30 to carry the whole brand. I'm sure it will be a good camera but it's hardly a flagship to keep folks happy and staying with Pentax till sometime next year.
06-15-2012, 02:32 PM   #58
Based on my calculation with partial utilization of Feynman Diagram, the probability of this rumor being true is roughly 66.6%, give or take 0.753%. This however is forever complicated by Heisenberg's uncertainty principle in that no rumor can ever be validated at aany particular point in time. Even if confirmed by Pentax themselves, it's existence would be paradoxical at best in that Schrodinger's cat is as dead as any rumors spun by RH. In conclusion, it is doubtful that even Pentax actually exist at all. So FF for sure by photokina.
06-15-2012, 02:34 PM   #59
Well that would be a pitty, but on the other hand, presenting it on PhotoKina with a fast market introduction would also be good. Maybe we have to get used to a new two year rotation with our camera's instead of the 17 months that was before.
06-15-2012, 02:37 PM   #60
QuoteOriginally posted by Fontan Quote
I'm honored
cameras, dslr, frame, full-frame, pentax, pentax full frame, rumor, rumors, sensor, sony
The full frame Pentax? slackercruster Pentax DSLR Discussion 18 02-13-2012 10:09 AM
The full frame Pentax that never was dj_saunter Pentax DSLR Discussion 23 05-06-2011 04:06 AM
Pentax and Full Frame oppositz Pentax DSLR Discussion 58 03-18-2011 09:39 AM
Pentax and Full Frame... Shutter-bug Photographic Technique 60 11-03-2010 10:03 AM
Pentax A 50/1.2 on Full Frame aegisphan Pentax SLR Lens Discussion 23 10-28-2010 04:16 PM
All times are GMT -7. The time now is 01:55 AM. | See also: NikonForums.com, part of our network of photo forums!
