Originally posted by Clavius What if they were already working on one before the Ricoh switch? Then it could even be unveiled in September. Together with a FF lineup... The the three FA ltds in DFA form with WR and DC motors.
I know it's not realistic; just trying to rescue this thread.
There's too much other stuff going on at the moment. The transition period wasn't easy. I'd be really surprised if they have one ready for photokina.
Hoya was tough to work under. If they've worked on FF back then, it was only a small team, and not full time.
It'd make sense for Pentax not to release a high-end FF-body for their first FF-camera. There's not much market for that.
Rather have something like the D800. Doesn't take magic to develop it, either.
The problem with such a release is -- by that time, the prices for D800 and 5DMIII will be lower than they're now, so what price range to aim for!?
An affordable FF-body surely will gain momentum.
Originally posted by Fl_Gulfer Full frame cameras
PROS
take full advantage of wide-angle lenses
allows the photographer to move in closer to the subject and so reduce the depth of field
the larger sensor has manufacturing advantages that can result in less noise in your images
great for landscape photography and often preferred for street photography
CONS
more expensive than APS-C
more difficult to fill the frame with distant, easily-spooked subjects like birds
The wide angle thing isn't an argument imho. Just look at how well some UWA-lenses perform on APS-C.
Full frame isn't that great for photography with long lenses, either, like you say.
Of course, if you have a high resolution FF-sensor that has the same pixel size of an APS-C sensor, then you can crop without loss (well, in theory).
What it really comes down to is image quality/higher resolution (or same resolution at better specifications) and better control over DOF.
