Originally posted by abacus07 There's a problem with your argument still. You are right that comparable FF lenses don't exist for several of the DA ltd's. The problem is that those small comparables lenses will never exist. So if I buy a FF camera then I will need to buy larger lenses. There is pretty much no disputing this.
Just to be (less?) clear, sometimes some of us are talking about real lenses and sometimes we're talking about hypothetical products, like any Pentax FF camera or associated lenses.
Real Lenses:
There are certainly lenses which are small for APS-C cameras that don't exist for FF's (23mm F/6 lens). But the smallest, lightest APS-C lens I know (40mm f/2.8 XS - or 61mm F/4.3 as a full-frame equivalent), is a very capable full-frame lens. If you don't mind cropping in post, it's like a 26-40mm F/1.8-2.8 zoom on APS-C, with instant zoom, and for 50 grams! Even a 26mm F/1.8 would be probably 400-500 grams or so, given that the 31mm is what, 350 grams or so?
So I disagree - I think there is a lot of information that disputes the "fact" that full-frame lenses need to be larger than APS-C lenses.
You could argue the 40mm it doesn't cover full-frame, but I'm guessing the full-frame vignetting on the 40mm at F/4.5 is better than the APS-C vignetting at F/2.8. I could be wrong there, of course... but the 40mm is certainly very close to full frame.
Other lenses
Most people who buy FF are enthusiasts and would be on APS-C, too - so I see no sense in comparing an APS-C zoom with an equivalent aperture of F/6 to a full-frame zoom with an aperture of F/2.8. The same is true for most primes that are available for APS-C.
The only exceptions I can think right now are things like
1) 15mm F/4
2) 21mm F/3.2
3) 8-16 Sigma f/4.5-whatever
So these slow lenses have no equivalent on full-frame that I'm aware of. In general, though, for most "enthusiast" lenses, the FF-lens is cheaper and lighter, or doesn't exist. And of course, just like with telephoto lenses, you could always crop a wide-angle lens, too.
APS-C certainly does have some legitimate advantages, though:
1) Any photographer who doesn't post process can get a crop advantage
2) Maximum rate is usually quite higher
3) Very slow lenses (F/4 and up on APS-C, F6 and up on full-frame) are basically unavailable on Full-frame, so if those lenses have some advantage and are adequate for a photographers needs, then that's an advantage
4) Initial cost of the camera is lower
5) The APS-C camera should/will have a slightly smaller prism hump
6) The APS-C camera should/will be a bit lighter
