Ah, I see what we have here is a reference to an opinion. There are so many holes in this opinion that it doesn't stand up at all. But listen to what the guy says...
Quote: APS-C lenses are often heavier, larger, and more expensive than full-frame lenses. APS-C lenses almost never perform as well in some objective measurements like image resolving power.
What system should you buy? If you have an APS-C and rarely shoot wider than F/4, you'd only be giving up the superior resolution if you continued on APS-C. If you're often at F/2.8 or below on APS-C, it might be better to make your next camera purchase a full-frame camera.
The article though seriously flawed, and not at all technical, comes to a valid conclusion which I'd support , even though his methodology really sucks. That's because he's relating his experience with his shooting style, and even though conceptually he lacks a lot, he just puts together an ridiculous argument to illustrate his point,you can still learn from his conclusion. Please don't get caught up in his silly tables and graphs. They don't mean what he thinkins they mean. What you need to do is go through your images and see how often you shoot below F 2.8 .
If I look at my setup... I have an FA* 50mm 1.8 that is half the weight of my 70 mm Sigma 2.8, it's rough equivalent in FF. Both are FF lenses. Both can be used on my APS-c cameras. People in APS-c land can buy any light weight FF lens they want. Not so for FF an APS-c. So on that part of the equation, the man is just dead wrong. As for his assertion about noise, he forgets, that's only an issue, if noise is noticeable. When I'm shooting up to 800 ISO on my K-5, noise isn't an issue, and neither is this argument. The K-5 has excellent noise reduction software built in, which negates the noise argument to a large degree.
So there is a very limited set of circumstances where this article is correct. Like when using the Nikon equipment he used as an example, when assuming that you need the extra resolution an FF may (or may not) because if you aren't using a tripod, talking about which camera will take the the higher resolution picture is going to be determined by who has the steadier hand at the moment in question, not FF or APS-c.
Then why don't people just buy FF lenses and use them in place for APS-c lenses? They fit on the same cameras. Any lens you can use on FF , you can use on APS-c, they don't get heavier just because you put them on an APS-c camera. If you think about the topic from a different angles, you start realizing how narrow this view point is.
Quote: APS-C lenses almost never perform as well in some objective measurements like image resolving power.
The limits of resolving power have been studied to death. Resolving power is an issue only if you need resolution. Resolution is like horse power in a car, you can drive a car with 170 HP or a car with 279 HP and most of the time you won't be using more than 50 or 60 HP in either of them. Whether or not you want to pay for the extra HP for the times you need it is a personal decision, but 99% of the time it doesn't change anything, except maybe your sense of confidence. Resolution doesn't really affect IQ on shots reduced to under 3000 pixels, when talking a D800 and a K-5, based on my research. It may be in the future that everyone will be using 4000 horizontal resolution monitors and your pictures will look better if they were taken with a 645D or Nikon D800, but that's hardly an APS-c vs FF issue. A 16 Mp Merril looks very good compared to a D800 image at large size, there are many other issues besides straight up resolution that go into determining how good a picture looks.
The guy is really bang on in his conclusions despite the limitations of his data. Look at your images exif. If a lot of keepers are f-2.8 or below you probably want FF. In my case less than 1% of my keepers are shot at 2.8 or below. Less than 10% of my keepers are shot at an ISO over 800 and those are all birds in flight. Anyone enamoured with very shallow DoF will want FF. Anyone who shoots mostly for wide DoF is going to be just as happy or possibly happier with APS-c unless they shoot action in low light. Anyone who shoots Hi Res is not going to be happy with FF either. FF is a compromise in the hi-res world.
My favourite lens right now is my A-400 5.6. As a telephoto it's DoF is shallow, I crop the images as much as 50%. On an FF camera I'd be cropping 75% and getting exactly the same image (given equal pixel pitch) with the same lens, exactly the same depth of field, exactly the same noise levels. The fact that the author of the quoted article hasn't used this type of conception in his thought process doesn't mean they aren't valid. It just means he either didn't think of them, or didn't include them, because he wanted to keep it simple. Go with his conclusions based on his use of both systems, and you won't go wrong.
