Originally posted by Parallax If your needs require the capability of DOF so shallow that if you focus on a freckle the skin it's on is out of focus, then you certainly need an f1.2 lens and a 24x36 sensor.
This is the constant refrain, and it's just wrong, it doesn't describe anything close to a majority of situations FF shooters find themselves in.
Think of it this way - does micro 4/3 give you all the DOF control you'd ever need or want, or do you see the greater FOV/DOF versatility of aps-c as a useful thing, a noticeable thing that might cause you to buy aps-c over m4/3? Or for that matter, does the extra control over noise with the typical lenses help give aps-c an edge? If you think so, exactly the same conclusions can be drawn one tier up - and even more so, as the difference tends to be a bit greater between aps-c and FF vs m4/3 and aps-c.
It's never about razor-thin DOF. It's about finding more use and utility and control with common lenses, where you can realize some FOV/DOF and sharpness combinations that aren't quite as easily available with aps-c combos.
And if you think that's bogus, then I have to ask -
why do you shoot with aps-c and not m43?
