Originally posted by Digitalis Actually the Pentax SR system is able to be used under more general circumstances than a piezo driven multishot shift camera can. When you are using a multishot camera nothing in the scene you are photographing can move, which means using flash or powerful continuous lighting with the camera bolted to a tripod - otherwise you will encounter artefacts and ghost images. And i'm not sure if the Pentax Magnetic SR system is capable of the sub-micron levels of accuracy that the hasselblad piezo driven system can achieve. The Pixels in the K5IIs are approximately 4.8 µm - that requires some very high tolerances and some expensive engineering.
Dang, I wasn't aware of that difference, and it's implecations.
But I don't think the artifacts and ghost images are a reason for this feature not to be of any interest. With such an argument, exposure bracketing should be left out as wel then? No way!
Originally posted by Digitalis unlikely, if Hasselblad couldn't figure out a way around it: no one can - remember hasselblad engineered and developed the cameras that were used at the moon landings.
Someone else tried and failed, so no one else should do any more attempts? You're not working for a boss, I figure? Attitudes like that get employees fired.
The moonlanding might be impressive if my phone didn't have over 100x the computing power then the equipment that they brought along on those moonlandings. I have respect for that achievement, but is history.
Let me put it this way...
I have a simple free android app on my phone with which I can do handheld panorama's. I activate it, and hold it in front of me, with stretched arm, swiping the camera over the scenery. Immediately it snap pictures, and stitches the pictures together, live on the screen. When it can't match the pieces of the puzzle, it highlights the areas that I have to repeat. The pictures are of course of phonecam resolution, but there are no stitching errors. It's flawless. This tiny little free app, developed by 1 single (but brilliant) person, in his hobby-time doesn't make this stuff feel like rocket-science. Nor does it seem like Hassy-grade-expenses are required.
Now... Why can't any prosumer or pro grade camera do this many times better? If this is possible with a static sensor on the end of my streched arm, then in-camera managed SR rapidly taking 4 pictures in each corner of it's SR system and sticking them together doesn't seem al that hard anymore. It doesn't even need to recognize image features or stitch them together, because it already knows the 4 positions of the sensor.
