Originally posted by bossa The Pentax FF lens selection was designed for static film cameras and so if they implemented IBIS via SR on a new FF camera I would expect the FA limiteds etc to require switching SR OFF. We would probably end up with random dark artifacts around the edges of images due to the Image Circle not being large enough to handle the moving sensor.
Why would you end up with artifacts even assuming there was not an extra 0.3mm of wiggle room in the image circle? If there is no light there, there is no light to activate the sensor and nothing to generate artifacts. Worst case you would get a darker corner/side in the direction of travel. It could probably be corrected automatically in Photoshop/Lightroom if you made a plugin and knew the acceleration used and the coverage of the lens (or just look for an intensity gradient).
And many lenses have an image circle much bigger than strictly necessary. For example, the Fish Eye Takumar has an image circle more like 45mm (someone built a rollfilm camera to capture the full circle). The SMC Takumar 35/3.5 reportedly has a much larger image circle, one the order of 50-55mm IIRC, but with sharpness loss towards the edges. Someone else was doing stereo images with the fisheye and the 35/3.5, but I can't find the page at the moment. They sold their rig on APUG a while back.
http://photo.net/classic-cameras-forum/00YQrJ
Some large format lenses are mechanically vignetted to prevent light from bouncing around the body and causing flare, but I don't know if that is common on 35mm. My gut says not, because with retrofocus lenses smaller angles of coverage should be necessary. The few examples I've found of people doing full-image-circle capture suggest they are not mechanically vignetted.
edit: Dug up the other site:
Quote: Above is a photo of the camera with a real M-42 (Pentax) screwmount, replacing the original plywood friction fit mount. (Thanks to Tony Z). I have tested it using my 17mm f4 Fish-Eye-Takumar and my SMC Takumar 35mm f3.5 lenses with excellent results. The fisheye produces a sharp 45mm circular image. The 35mm lens produces a 54mm circular image with some colour fringing in the outer 2mm. The camera is basically completed except for gluing down the flocked paper that light seals the front and permanently attaching the fisheye viewfinder.
http://www.angelfire.com/ca/erker/fisheye66.html <-- site
https://www.pentaxforums.com/forums/sold-items/162920-sale-sold-custom-made-f...r-17mm-f4.html <-- sale thread
