Originally posted by LaurenOE Yep. Exactly. I want to go bigger and the D800E seems to be the sweet spot.
Sure, I have 645 lenses, but I just can't justify the 645D just to stay with Pentax.
The hole between the K5IIs and 645D should have something in it already, and is the basis for much of my frustration.
Actually, all D800 / D800E benefits can be get only if:
- you use tripod, good one
- you use mirror up function
- you use wired trigger, or similar, to avoid button push shake
- you use only the best lenses available, sharpness and contrast
- Focusing is done right, many times this requires service made calibration using actual lens set or live-view MF
and most important, D800E is better than D800 only if:
- you do not shoot wide open or close aperture too much, but use lens sweet spot, that is aperture closed to f:4 - f.5.6 range. This is the condition I seldom meet.
If you do not meet those conditions, paying more to get D800E is waste of money, . Here D800E is 700 € more than D800, so I decided not to buy it.
