Originally posted by Harald Please read carefully before start flaming. I said "all" benefits. If you blurr your pictures by handholding, you cannot get all benefits.
I wasn't flaming, I was pointing out your error, very nicely.
And may I suggest you read more carefully, because you just repeated the point I refuted - when you say "get all benefits", you're basically saying 'maximizing', which I'm telling you isn't required.
In fact, 'maximizing' in a lot of circumstances only brings the last 5%, maybe 10% of the net benefit. (note I said 5% of net
benefit, not 5% more resolution - in other words, you might see 20% better resolution going to a D800 and using Zeiss lenses, mirror-up, $1000 tripod, etc, but might see about an 18% improvement by shooting the 50 1.8G handheld at adequate shutter speeds - is that extra 2% worth the mirror-up, $1000 tripod, and Zeiss? Especially when it's not really visible at less than 200% crop?
Repeat after me:
Keeping your methodology exactly the same, you will see benefits to higher-res, FF sensors. You don't need to maximize things to see the benefits, in fact this attempt at 'maximizing' can sometimes bring annoyingly diminishing returns.
Quote: Bossa: You too should read texts more thoroughly. Yes, K-5 is easily hand holdable and so is D800 too. BUT, if you want sharpest possible result (and if this is not your goal, why spend 2400 € instead of 1000€?)
Because you can get better - sometimes much better - results than before even keeping your methods exactly the same (see above.) And you get an extra stop, more DOF control, better AF, etc, etc (meaning 'sharpest results' isn't the goal for the D800 buyer the majority of the time - it's maybe just an added bonus for many.)
