Originally posted by Clavius LOL!
If I make a box for a as small as possible for tiny Fiat 500. And then later I take out the Fiat 500 and manage to shoehorn a big longhaul truck with a 40' container in that very same box. Then we can safely conclude that that box wasn't as small as it could have. We most probably don't have to take the box apart for that.
well , in this case, unless you can show me there isn't space left in the K3 enclosure, i don't see why not. And that's beside the point.
we are speculating, not making definitive statements. from your line of replies, i can feel some hmmm, tension with this issue? have you seen the specs on the lastest Sony model? it has most of what the K3 has i terms of extras (mic jacks, input out put, RGB sensor etc... for a smaller frame! ok, there isn't stabilization on the sony model, but then again, the K3 is Approx. 131.5mm (W) x100mm (H) x 77.5mm (D) (excluding protrusions) and the sony is 127 x 94 x 48 mm (5.00 x 3.70 x 1.89″) so considering by how much the sensor has to move to be able to cope with the stab. I'm wondering if it's possible.
