Originally posted by rawr K-mount is a big part of Pentax's identity. And Ricoh have publicly said they are committed to it (in one of the other 9 million threads where this issue has been pored over).
Plus why isn't anyone mentioning the simple 'no-additional-space-required' solution to fitting electro-mechanical SR into a FF K-mount: they can just use digital SR
Pentax can't afford to be the only player left without a FF camera offering.
The other big players have been smart enough to not only move to FF, but also to continue to support APS-C.
Ricoh will most likely do the same.
It would be a near certain bet that Pentax engineers are working their butts off to fit a FF sensor and its supporting machinery inside the K mount.
Almost any engineering problem can be solved if you throw enough money at it. But - and here's the rub - a point is always reached where cost/benefit analysis steps in and a purely business decision has to be made about whether the solution is economically viable. What I think will happen, is that Pentax (Ricoh) will do what the others have done - offer a FF camera at the same time as APS-C - as separate lines. The FF will become their professional/advanced amateur line and the APS-C will be for enthusiasts.
Yes, there may have to be a new line of lenses, but this hasn't stopped Canon.
Pentaxians will howl, but we will get over it.
If you really want to hear howls of anguish from a customer base - listen to the Canon crowd who have been messed around for years - right back from the days of the Canon FD breech lock mount.
Of course, if a whole new line of lenses is is needed, perhaps a chance to get ahead of the crowd and offer a bigger sensor than 36X24mm but smaller than 645 will present itself.
Let's face it - the current FF thinking is based on the old 35mm concept, and nothing holds us to that except legacy lens design.
If a break from that is needed then think outside the 36X24 frame.
The old 127 film format presented a 40X30mm image and was once very popular.
Who knows..............
