Originally posted by Kunzite I doubt the effort to support an APS-H line is smaller than the one required for "full frame". The sensor could be an issue (Ricoh would have to secure a constant supply of high-quality custom-size sensors; no good if they're worse than APS-C), a new line of lenses would be needed anyway (nope, APS-C lenses that marginally works are not a solution), everything else is pretty much the same.
In other conditions, if the sensor size had a more dramatic effect on cost, an intermediary format would made sense; but this is not what's happening, on the contrary, the cheapest "full frame" are only $200 more than the most expensive APS-C (and that's an old model, long due for replacement). I don't see any room for APS-H, one that would make the effort feasible.
Well My starting point is that the sensor will be good and better performing then current aps-c sensors. I have no idea why people start to think overhere thet the sensor inside the new Phase One IQ250 50 megapixel cmos sensor would not be of current level of IQ from a pixelsize seen.
On the performance of current lenses there is a nice question. Maybe someone with the Sony A7 and adapter could answer on these. So wich lenses in production today would perform well on aps-h? (and maybe even also on full frame).
The yes: DFA 100mm and 50mm Macro; FA 31mm, 43mm and 77mm; DA*55mm, 200mm and 300mm.
The maybe: DA 35mm, 40mm, 50mm 70mm, 560mm, DA*60-250mm.
The No: DA35mm macro; DA 14mm, 15mm, 21mm, 10-17mm, 12-24mm, 17-70mm, 18-55mm, 18-135mm, 18-270mm, 20-40mm, 50-200mm and 55-300mm; DA*16-50mm and 50-135mm.
So only 6 lenses in the maybe section, while the lenses in the yes section will perform better (les vignet) on the smaller aps-h then on full frame. If a few off the lenses in the maybe section will do better on aps-h then there is point!
