View Poll Results: Do you think FF will be announced at Photokina?
Yes 21632.58%
No 44767.42%
Voters: 663. You may not vote on this poll
Show Printable Version 125 Likes Search this Thread
09-02-2014, 05:34 PM   #496
QuoteOriginally posted by GlassJunkie Quote
Agree that the 1:1.7Q is far weaker in the end, but I believe it is due to a higher mag ratio to end media and insufficient pixelation density to make up for the larger magnification needed to display/view it...
With higher MP it would also require significantly sharper, better-corrected lenses and extremely accurate AF to have any hope of matching aps-c or FF for higher-end telephoto. It also is not going to be able to provide the same subject isolation, bokeh quality, etc, unless they can design some radically fast lenses for it.
I guess what I am saying is 1.5:1 is sig less with the other variables than the Q 4.1:1
It is, the 'Q' was using an extreme to prove a point though - going down in sensor size to try to take advantage of pixel density for 'telephoto' operates on a rapidly-diminishing curve, in part because of those aberrations, focus errors, and just lens limitations.
09-03-2014, 08:50 AM   #497
GlassJunkie's Avatar
QuoteOriginally posted by ElJamoquio Quote
Just to be clear - you think the Q would be substantially better, with, say, 24MP or 36MP?
If you can manage pixel "crosstalk" (the extra light bouncing around pixels from the pixel next door), I would always take the higher res (pixel density per sensor size), accepting that the smaller glass needs to perform better since some aberrations may be magnified. They are mostly manageable algorithmically (in camera preferred or Post produx).
I don't know of anyone cramming 24-36mp in a 1:1.7 (commercial or not). A lot of shoehorning.
09-03-2014, 10:19 AM   #498
ChristianRock's Avatar
But they are putting 20+ MP in a 1/2.3".
09-03-2014, 10:25 AM   #499
VoiceOfReason's Avatar
What is the size of the sensor in the Nokia 808 pureview? I know it is supposed to be a 40mp sensor, but what size is it?
09-03-2014, 10:41 AM   #500
Yes 20mp in 1:2.3
QuoteOriginally posted by ChristianRock Quote
It is getting closer. I don't know where it will end up.... Where the diminishing returns are with all of the variables:
  1. pixel pitch
  2. sensor size
  3. image circle
  4. human resolving need by media (what is it worth/ cost for print/ video/pc/phone)....
  5. in-camera processing
  6. aberration management (in-camera/ post processing) algorithms
  7. storage
  8. battery life/ power drain....
  9. portability
  10. ruggedness...
  11. optics... Glass will be a constraint(thresholds/ constraints on deliverable resolution to the sensor)
all are part of the equation.
I am anxious to see who picks up the Toshiba sensor... In stills....
09-03-2014, 10:58 AM   #501
I would always take the higher resolution file, too, but you have one big IF in there, and there's another - light hitting the 'wiring', that microlenses attempt to fix but do not do so perfectly.
File size and file transfer time, buffer time, etc would be adversely affected.
Those are some of the minuses.
The pluses? Better resolution, sure, but on a lp/mm basis the Q lenses are already the highest testing lenses out there to my knowledge. I doubt they'd improve much when you triple resolution, especially since, among lenses out there, they're already at their best wide open - i.e. diffraction is causing a significant portion of the softness.
If there were an 8mm F/0.2 or F/0.5 released, though, of course it would no longer be diffraction limited.
It's a case of diminishing returns, and on a smaller sensor with equivalently-slow lenses, you're close to the limit already.
---------- Post added 09-03-14 at 11:00 AM ----------
  1. Marketing
  2. pixel pitch
  3. sensor size
  4. image circle
  5. human resolving need by media (what is it worth/ cost for print/ video/pc/phone)....
  6. in-camera processing
  7. aberration management (in-camera/ post processing) algorithms
  8. storage
  9. battery life/ power drain....
  10. portability
  11. ruggedness...
  12. optics... Glass will be a constraint(thresholds/ constraints on deliverable resolution to the sensor)
How could you forget the most important reason? Fixed that for you....
09-03-2014, 11:02 AM   #502
THX. Lost it there, have a head cold....Appreciate the backup...
09-03-2014, 01:01 PM   #503
Banned
QuoteOriginally posted by VoiceOfReason Quote
09-03-2014, 01:07 PM   #504
Crop factor of ~3 from 36x24 IIRC.
09-04-2014, 02:07 AM   #505
Samsung have apparently solved this problem in some of their mobile phone cameras (ie the Galaxy S5, the mobile phone with the #1 image quality ranking on DxOMark), and have now applied the same technology in their new 28MP APS-C flagship camera the NX-1 (the first APS-C to break the 28 MP barrier).
They call it their 'CMOS ISOCELL' technology, which:
ISOCELL technology forms a physical barrier between neighboring pixels – isolating the pixel. This isolation enables more photons to be collected from the micro-lens and absorbed into the correct pixel’s photodiode minimizing undesired electrical crosstalk between pixels and allowing expanded full well capacity (FWC).
Compared to conventional BSI pixels, the ISOCELL pixels decrease the crosstalk by approximately 30 percent which results in higher color fidelity to reproduce the original color with sharpness and richness, and increase the full well capacity (FWC) by 30 percent which leads to greater dynamic range.
Samsung Launches ISOCELL: Innovative Image Sensor Technology for Premium Mobile Devices
Be interesting to see how it works on the NX1.
09-04-2014, 02:25 AM   #506
Banned
NX1 is a pretty impressive looking machine!
No LED's though, get with the program Samsung
09-04-2014, 02:32 AM   #507
Fogel70's Avatar
Samsung have apparently solved this problem in some of their mobile phone cameras (ie the Galaxy S5, the mobile phone with the #1 image quality ranking on DxOMark), and have now applied the same technology in their new 28MP APS-C flagship camera the NX-1 (the first APS-C to break the 28 MP barrier)..
Samsung have not solved, but improved the cross talk with 30%.
I'm not sure how much of a problem crosstalk is on other APS-C sensors, but an improvement of 30% might not be all that much. Fi a change from 10% to 7%.
So I would not expect the improvement to be very large on APS-C sensors, but if Samsung finally can make sensors in the same league as Sony it would be really great.
09-04-2014, 03:07 AM   #508
QuoteOriginally posted by Fogel70 Quote
Indeed. Maybe Pentax might revive it's old technology sharing agreement with Samsung if this Samsung sensor tech works out OK
I bet this tech will perform even better if they use it in a FF sensor.
09-04-2014, 04:59 AM   #509
Fogel70's Avatar
Crosstalk is usually a bigger problem on small sensors (small pixels). Just like BSI, ISOCELL is mostly designed to improve IQ on small pixel sensors in smartphones.
09-04-2014, 07:25 AM   #510
I was actually surprised at how well my Galaxy S5 does for pictures, but I didn't know it was because of a different tech.
24x36mm, 35mm, a7, angle, banners, body, camera, canon, da, da lenses, dslr, fa, ff, full-frame, jump, lens, lenses, market, nikon, option, pentax, ricoh, roadmap, rumors, signature, time, tokina
Weekly Challenge POTW 2February 2014 to 16 February 2014 bucfan1234 Weekly Photo Challenges 23 02-18-2014 05:28 PM
Weekly Challenge POTW 26th January 2014 to 9th February 2014 bucfan1234 Weekly Photo Challenges 19 02-09-2014 06:01 PM
CES 2014 and CP+ 2014 Uluru Pentax News and Rumors 134 01-25-2014 09:11 AM
Photokina 2010 is history, and there was no FF announcement. What now? ilya80 General Talk 25 10-09-2010 08:34 AM
I think the Pentax FF will be announced at Photokina 2010 whatever7 Pentax News and Rumors 106 02-04-2010 12:45 AM
All times are GMT -7. The time now is 06:39 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
