Originally posted by dtmateojr Image height for full frame is 24mm right? The D800 is 4192 pixels "tall" which gives you 175 pixels/mm. MTF50 is roughly half of that so give or take 90 lpmm MAX.
So it's impossible. There, I showed you the simple algebra.
Edit:
Ok here's another angle to his test. It could be that he is able to detect approx 1000+ lines in a 24mm image. In that case he is still not maximizing the sensor which is capable of 2000+ lines at MTF50 for a 24mm image height.
The lens isn't at fault here but the methodology. His image does not have enough lines to max out the sensor.
Not quite sure what your point is - are you imagining the shape of the curve will change in either case? ( Or the curves will all of a sudden meet at f/11?
LensRentals presents it in a form that simplifies cross-format comparisons better using that arbitrary scale (I think 500-1300 IIRC) - lp/mm is just as good but requires a conversion to extrapolate results between formats. That's all. The curves don't change, only the units do, they're both derived from Imatest, and it tracks DXOMark, SLRgear and photozone results.
Also, the methodology used in the "sharpening Joker's" tables is
here. Make sure you look at the PDF linked near the bottom of the page. Looks like they use actual DxOmark data, and a Matlab function from Norman Koren. (you may have heard of him.)
