04-16-2014, 12:33 PM   #136
Nesster's Avatar
Question: before retrofocal wide angles, why would you have picked a SLR over a RF?
Being a 105mm or wider kind of guy (Am I allowed to say that here, I mean it in the FF terms...) Or Being a 70mm or wider guy I would hope Pentax adopted the 5 way SR from Olympus and ideally integrated it in 4 dimensions to combat my flapping arms... and I suppose I'd have to develop a sudden passion for ultra telephoto birds and nature shooting.
Or, I'd just use the kit lens. And use the legacy glass just to show off I mean play around with. If Pentax suddenly went Olympus on us.
04-16-2014, 01:30 PM   #137
jsherman999's Avatar
QuoteOriginally posted by Parallax Quote
Concerned primarily with FOV, but to some extent noise. DOF? Meh.
There are reasons the three (FOV, DOF and noise) have to be tied together there (ie can't just lose one but not the other,) but leaving that alone for now: is it reasonable to assume that if you had legit concerns about losing noise control moving from aps-c to m43 with your same lenses, that someone else might have equally legit concerns moving from FF to aps-c? Or maybe even more understandable concerns, since the sensor-area delta between FF and aps-c is greater than that between aps-c and m43?
04-16-2014, 02:14 PM   #138
Senior Moderator
Parallax's Avatar
That's absolutely reasonable. I'm not convinced however that noise has anything to do with sensor size per se. If you trim a 24x36 sensor to APS-c dimensions, or an APS-c sensor to micro 4/3 it's the same sensor, just less of it. A 36Mpx 24x36 vs a 36Mpx micro 4/3 is a different matter.
04-16-2014, 02:23 PM   #139
cali92rs's Avatar
Compare the noise of a Q and K-5 at ISO 800.
Sensor size is THE determining factor in the difference in noise.
04-16-2014, 02:29 PM   #140
Senior Moderator
Parallax's Avatar
QuoteOriginally posted by cali92rs Quote
Those are 2 different sensors. The one in the Q is not a trimmed down K-5 sensor. Put a lens on a Nikon D600 and take a shot in full mode, then the same shot in APS-c mode then compare the noise level.
If that were true, then the noise of the K-5, K7, K20D and K10D would all be exactly the same because they all have the same size sensor.
Compare the noise of a Fujifilm X10 to a K10D at 800.
04-16-2014, 02:39 PM   #141
cali92rs's Avatar
OK, I was overgeneralizing...still it is probably the biggest factor.
You are comparing cameras of different ages and generations.
How about the D600 vs the D7100?
That is about as apples to apples as your going to get.
Same processor, same resolution, both sony sensors.
Nikon D7100 versus Nikon D600 - Side by side camera comparison - DxOMark
The D600 trounces the D7100 when it comes to noise.
Why?
04-16-2014, 02:44 PM   #142
Senior Moderator
Parallax's Avatar
Again, 2 different sensors. An 8 ounce filet Mignon is going to be more tender than a 6 ounce sirloin which is certainly more tender than a 4 ounce chuck steak. Does that demonstrate the bigger a steak is, the more tender it is?
04-16-2014, 02:47 PM   #143
Na Horuk's Avatar
The D600 trounces the D7100 when it comes to noise. Why?
Possibly because the D600 has a greater bit depth (25.1 bits).. just like the K-5 has better noise performance (and DR) than the K-30, because of some extra bits.. even thought it is the same Sony sensor
04-16-2014, 02:49 PM   #144
cali92rs's Avatar
Again, 2 different sensors. An 8 ounce filet Mignon is going to be more tender than a 6 ounce sirloin which is certainly more tender than a 4 ounce chuck steak. Does that demonstrate the the bigger a steak is, the more tender it is?
One is a top of the line APS-C sensor....the other is a middle of the road FF sensor.
The 8 ounce chuck steak is beating the 4 ounce filet mignon.
04-16-2014, 02:51 PM   #145
JinDesu's Avatar
Why not just compare the D800 to the D7000/k-5/whatever? I thought the D800's sensor was the big brother version of the k-5 sensor. And this is reflected that in the per pixel noise: they match. It's just that the D800 is larger and has more pixels so when scaled, the D800 does better.
04-16-2014, 02:54 PM   #146
cali92rs's Avatar
The K-5 has 14 bit Raw, the K-30 has 12 bit Raw.
The D600 and D7100 both have 14 Bit Raw.
You guys are really stretching here.
04-16-2014, 03:00 PM   #147
JinDesu's Avatar
But the D610/D600 beats the D800 in high ISO too. It's a factor of different sensors. The D610/D600 likely wins out due to the larger photosites, but the D800 also is no slouch. Just commenting on the idea that the 8 ounce chuck steak also beats out the 8 ounce filet mignon..
04-16-2014, 03:09 PM   #148
On a per-pixel level, the D800 and the K-5 have the same noise level.
On a noise in a picture level, the D800 trounces the K-5 if DOF is allowed to change.
At the same DOF the D800 and the K-5 will have the same noise, you can see that it's within spittin' distance in the chart below.
http://drcameraphd.blogspot.com/2013/04/fitdoesntmatter.html
04-16-2014, 03:10 PM   #149
Senior Moderator
Parallax's Avatar
Just because you guys are not convinced does not make it true. It means you do not understand.
So if size is "THE" factor then a photo shot with a D800 in full mode will have less noise than one shot of the same scene, same lighting, same exposure, and same lens in APS-c mode, right? If size is "THE" factor, it would have to be, right?
04-16-2014, 03:16 PM   #150
Huh?
What are your constants and what are your non-constants?
It sounds like you want to keep constant:
1) Focal Length
2) 'Exposure' - i.e. aperture and ...
3) shutter speed
If you keep those two constant the chart I posted shows there's ~60% improvement in noise.
24x36mm, aperture, aps-c, camera, check, da, dof, equivalence, f/8, ff, ff resolution, full-frame, lenses, mf, pentax, photo, photography, post, practice, reasons, resolution, sensor, shot, shutter, theory, time, wrong
How to shoot a wedding with APS-C and FF nick52 Photographic Technique 8 08-05-2013 05:14 PM
K-5IIs reviews at Amazon - Better than FF Canon? Docrwm Pentax K-5 4 02-19-2013 12:12 PM
Quick question regarding field of view - FF vs APS-C glass? Julie Pentax SLR Lens Discussion 5 12-23-2012 05:33 PM
APS-C does not increase focal length over FF, it decreases field of view. TomTextura Photographic Technique 135 06-09-2012 04:58 PM
What is your best example for FF over APS-C? leeak Pentax DSLR Discussion 21 12-11-2008 12:25 PM
All times are GMT -7. The time now is 08:46 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
