Originally posted by northcoastgreg If that is the fundamental tenet of equivalency (I doubt that it is), it constitutes a false ideal.
It's not an 'ideal' in any way, shape or form, it's simply a statement of physical fact. "F = m a" is not an enforcement of an 'ideal', it just *is*.
Quote: All pictures may be "possible" on all formats in the same broad philosophical sense that "anything is possible," but in terms of reality, it's just not true; or, in the sense that it might be true, it's just not practical.
Of course it isn't always practical, or even in some cases possible when you consider the lenses you can actually buy.
Understanding equivalence just helps you determine what is practical economically and even possible based on available options when you move between formats.
For example, if you want to re-create the experience you had with your 50mm prime on FF when you move to ap-sc, you pick a 35mm prime and get about the same FOV. If that's all you care about - if you don't care about DOF or noise - you're done.
You just used equivalence to get there, to decide what lens you need. Now, if you do care about DOF for the same FOV you had before, you will need to pick a 35mm lens that has about a stop faster max aperture, or you will lose the DOF control you had wide-open to about 1.3 stops down from wide-open, and you would lose the noise control you had in that range as well. To some people, that matters - to some, not, but to say that if it doesn't matter to
you so it shouldn't matter to
anyone is silly - that would be like saying "
I shoot micro 4/3, and everyone should, because the small difference aps-c brings isn't anything anyone should care about."
You could use equivalence in part to make an economic decision on a telephoto combo - with sensors of equal pixel density, how much would it cost you to replace a 200 f/2.8 you shoot on aps-c (in FOV and DOF) with some combo on FF? If you understand equivalence (and the effects on your image of cropping and enlarging, because that's an option too,) you make the conversion and then go price your options. (hint: that combo slightly favors aps-c - it's
possible to do it in FF, but perhaps not
practical.)
Here's a general question to anybody: How would you feel - answer honestly - if Pentax suddenly said they were abandoning aps-c in favor of micro 4/3? Mount would stay the same, or there would be an AF adapter, so you could use all your same lenses - but the sensor was shrinking. Would it matter to you? Would you prefer they
not do that?
Why?
