Originally posted by Winder There is only 1 lens under $1,000. I chose the newest lenses that were designed for high resolution digital sensors. All those other lenses are much older film era lenses. Like the FA Ltds they need to be updated.
The industry is moving to smaller bodies and lenses. The 645z is going the other direction. The future isn't bigger and heavier. Is Pentax is working on a sensor that is actually 60mm x 45mm (56 mm x41.5mm) instead of 44mm x 33mm. IF the plan is to go to a true 645 sized sensor then the larger lenses make sense.
There's a big difference between implying all lenses cost $5000 and saying only one is under $1000. And there are many lenses under $1000 if you buy used. Perhaps future lens releases will also hover around $5000. This could be an issue someday, but your statements don't even accurately reflect today's new market - let alone the used one.
I find it ironic that you said the FAs need to be updated, "like the [K-mount] FA Ltds do." I have a fairly complete K-mount kit, with FA (and F) lenses at the core. The two lenses that
most need updating are the newer ones - DA* zooms. I like these lenses - in fact, I'm a big advocate of them both. But the DA*16-50 needs improved optical quality (granted, it's difficult in this FL range) and the DA*50-135 needs faster AF.
I don't read of people complaining about the quality of the FA 645 lenses on digital. And I don't think the MF competition has a large number of new lens designs either.
As to the larger sensor size - even Phase One and Hasselblad are slow to roll out new sensors. The development costs are high. It's one new sensor every few years, more or less.
Pentax will have to sell a lot of cameras to convince management - and then another company like Sony - to develop such a sensor for the next generation.
