11-08-2014, 12:01 AM   #1
ClinchShots's Avatar
Am I ready for full frame?
well I have another wedding tomorrow and I'm sure as hell going to find out
My equipment:
Pentax k30 with a sigma 30 f/1.4
Pentax k5IIS with a tamron 28-75 f/2.8
100 macro
50-135 f/2.8
My borrowed equipment
Sony A7R
70-200 f/4 stabilized
55 f/1.8
Sigma Art 35
100 mm Macro
20mm f/2.8
wish me luck...
reviews an comparisons to come:
I have done quite a few events and weddings with the k5iis and I think the quality images it will produce will hang with the A7r (not blown up 5ft x 5ft though)
I guess we will see.
11-08-2014, 12:26 AM   #2
LensBeginner's Avatar
Good luck wih your FF wedding!
Anxious to see the results...
11-08-2014, 01:47 AM   #3
Paul MaudDib's Avatar
I think it's down to your skill, that's more than enough equipment...
11-08-2014, 01:48 AM   #4
MarkJerling's Avatar
Well, that A7R is getting good reviews, so I'm sure you'll have some stunning shots. Please do post!
11-08-2014, 02:55 AM   #5
QuoteOriginally posted by ClinchShots Quote
My equipment:
100 macro
50-135 f/2.8
Sony A7R
55 f/1.8
Sigma Art 35
100 mm Macro
20mm f/2.8
wish me luck...
Keen to hear what you think of the full frame option and if it's really necessary
11-08-2014, 04:21 AM   #6
Best of luck. Weddings seem hard work.
Do you have a 2nd shooter?
11-08-2014, 04:30 AM   #7
Agreed have the utmost respect for wedding photographers, too much pressure for me.
11-08-2014, 07:34 AM   #8
Best of luck!
11-08-2014, 07:49 AM   #9
Mikesul's Avatar
Good luck and please do give us a full report. It will be very interesting to see how useful the A7R is in that environment especially up against the Pentax equipment.
My equipment:
100 macro
50-135 f/2.8
Sony A7R
55 f/1.8
Sigma Art 35
100 mm Macro
20mm f/2.8
wish me luck...
11-08-2014, 09:32 AM   #10
Rimfiredude's Avatar
I agree, shooting a wedding has to be one of the most difficult and pressure ridon things I have done. Have you ever backed up to get the shot and sat in the Wedding Cake. Unfortunately, I did. Glad those days are over.
11-08-2014, 09:41 AM   #11
aleonx3's Avatar
As rawr has suggested, I strongly suggest that you get a 2nd or 3rd shooter..... one person can not cover everything at the same time. Remember if you are not there, you cannot take it; and you also need someone to take shots at different angles and serve as backup as well while you are taking a break. I believe you have enough equipment to get it done and do a great job, good luck!!
11-08-2014, 10:20 AM   #12
RonHendriks1966's Avatar
Best of luck and make afterwards a list of equipement used and take less with you next time.
11-08-2014, 10:46 PM   #13
Lots of pros and cons
Tomorrow I will update on many things
And yes I always have a second shooter. It's a must
He uses a Sony A900 full frame and some really nice lenses
---------- Post added 11-09-14 at 12:49 AM ----------
Biggest flaw for the A7R?
The battery died in a little over 1.5 hours on a single charge so you would need to invest more money in the expensive camera to handle a wedding properly.
Best trait? Focus system, it's automatic processing of images, and lower light outdoors performance in a three way tie
---------- Post added 11-09-14 at 12:50 AM ----------
By investing more I meant buying a battery grip
---------- Post added 11-09-14 at 12:55 AM ----------
QuoteOriginally posted by RonHendriks1966 Quote
I did that before hand
Didn't use the macro, or the sigma 35 prime for the a7r
Didn't use my 16-45 f/4 on the Pentax
---------- Post added 11-09-14 at 12:59 AM ----------
Indoors my k5iis with the sigma 30 and af360 flash hangs hand in hand with the Sony minus what you loose in the crop which is very manageable if you know how to use a crop sensor (all Pentax users)
11-09-2014, 10:23 AM - 3 Likes   #14
okay pros /cons in depth for the A7R
I can put the A7R in auto mode and it will do all the tough work for me, It adjusts on the fly from landscape to portrait to backlit portrait and the pictures look flawless with great color rendition and the focus system was great at picking up faces and keeping multiple people in focus. I went to manual and ap priority and did manual adjustments but auto mode shooting in raw was flawless and very easy to use on the fly. On my pentax system if I put it in auto the pictures would be too dark and I'd see a lot of silhouettes, with Pentax I had to stay in manual and make constant adjustments. I was under a veranda so no direct sunlight, where I think the pentax would have kept up it was just a lot more difficult and time consuming to get a shot right on the pentax while I could fly through it with the A7r.
The 70-200 was epic and produced great images but for the cost I feel like they need to make it f/2.8 (it's f/4) and give it enough to use in a low low light situation. it was incredibly fast focusing and spot on every time
The battery life on the A7R was trash compared to Pentax. I shot for a little over 1.5 hours and that burned through a full charge while Pentax k5IIS I could go 5 hours easily. I feel like you need to buy a battery grip which is an extra expense on an already expensive set up.
with flash indoors with little ambient light the Pentax with my 30 f/1.4 holds its own with the Sony and the 55 f/1.8 while the sony pulls away fast outdoors Pentax indoors to me pulled ahead (which many weddings are held indoors for at least half of the event)
I took more keepers with the Pentax here than the sony
last con... The A7r is incredibly loud. There is no way to sneak candids when everyone can hear you coming with the shutter slap. I love shooting candids at weddings so I used my Pentax set up for this and on the K5iis the shutter seems to whisper compared to the Sony
editing for the A7r is very easy and lightroom makes little to no adjustments my edit from yesterday is nearly done on the 600 photos I took on the a7r (5 hour wedding) I took about 400 on my Pentax systems and my second shooter took about 500
skin tones look better on the K5iis and K30, while the A7R makes people look a bit pale white and needs PP adjustment a lot
the A7R is incredibly sharp at 100% crop... a lot like the K5iis but better and imo less miore effect
overall I'd love to own the A7R but it has it's limitations and I need to dive in deeper with it maybe with shoot 5-6 more weddings before I'm sold on it
I think I could make do with my current Pentax set up. The A7r pulls ahead in many areas but Pentax hangs close in others and for the value margin that's a big deal. Once I'm through the edit I will post comparison pictures
11-09-2014, 10:31 AM   #15
*snip*
A very informative post, full of interesting and meaningful info, post liked.
Also happy to hear that all went well with your gig!
24x36mm, a7r, battery, crop, equipment, f/2.8, full-frame, hand, k5iis, macro, pentax, post, sigma, sony
I am being asked for "Full Resolution" images jpzk Digital Processing, Software, and Printing 17 10-05-2014 05:56 AM
Nature Neighbors ready for nw to cut the grassm but I ain't ready,,,, Knock Post Your Photos! 4 04-25-2014 05:00 AM
I am a Full Frame Mess! dmbaile2 Pentax Full Frame 78 03-17-2014 11:32 AM
I am ready..... janneman Pentax News and Rumors 9 05-28-2009 10:05 AM
Am I confused about DOF and full frame lenses? bc_the_path Pentax SLR Lens Discussion 22 12-13-2008 03:06 PM
All times are GMT -7. The time now is 10:40 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
